pas problem
veilthe30
Sat Jul 20, 2013 11:19 pm
ok so my car has started to make a really loud noise when i turn the steering wheel. i took the pas belt of and then turned the wheel and the noise was gone i take it this means my pump is broken?
thanks
Sun Jul 21, 2013 6:35 am
Depends what the noise was. Belt was too loose/worn is the prime suspect.
Fluid level OK?
andrew_baran
Sun Jul 21, 2013 9:17 am
The wookie in my PAS system went away when I renewed the fluid and made sure the levels were good.
veilthe30
Sun Jul 21, 2013 1:12 pm
Fluid levels are a bit low so i will try draining it a puting new fluid in and the belt is a bit old but it wasn't sliping or lose I will change the fluid and report back
Thanks for the help
HairyScreech
Sun Jul 21, 2013 1:47 pm
groaning or squealing?
zd3bx
Sun Jul 21, 2013 6:04 pm
Also check if your PAS pipes are not pissing, as mine are, and I never seem to get the time to replace them :(
veilthe30
Sun Jul 21, 2013 11:27 pm
it a loud groaning and i think my pipe are leaking i will check them all out tomorrow :)
