Engine Change
reckless1986
Hi i have a 325i engine 2.5 and gear box i was woundering will it fit in my 320i and if so do i need to change anything
BenHar
verde
Shouldnt do, i put my 320 right into the 325 set up
I think we changed the prop but that was it
Raise hell praise Dale.
Depends on what age the relative cars are; if they're both later 1988-on Motronic 1.3 cars, then the engines can be directly swapped over, otherwise, you'll probably need to swap the engine bay wiring looms.
Also, if fitting an M20B25, you should ideally also fit the disc rear brakes and beefier front struts that the 325i had.
Grrrmachine
- E30 Zone Wiki / Team Member
reckless1986
ok many thanks i have changed all the other stuff just the prop and engine to go just wanted to make sure it would fit
many thanks to all who answered
