At home respray, where to buy bulk paint 5lt?
bmw9818
Fri May 31, 2013 9:06 pm
Planning to do an at home respray have brilliantred colour, and very bad Laquer peel on rear 1/4 planning to respray both rear quarters and rear end, wings and doors I will take off do rust repair and spray off the car, bonnet is brand new,
Bumpers will come off as well for a seperate respray,
Only thing remaining is roof and c pillars,
Would a 5lt tin cover it? Would obv prefer one big tin instead of seperate litre tins etc incase the shade varies, Ive asked a few body shops they all said no, halfords can only supply a 1litre tin,
Grrrmachine
E30 Zone Wiki / Team Member
Fri May 31, 2013 9:17 pm
5 litres will do a whole car.
Do you have any experience with spraying paint? Are you aware of the equipment requirements and the health risks? It's not for the faint hearted.
scjimbo
Fri May 31, 2013 9:44 pm
Most paints are water based now which is good. You must NOT spray 2 pack paint at home without the correct respirator equipment. You need a compressor that will keep up with the gun and also very very importantly a compressed air dryer.
I used to spray guitars. Which believe it or not is almost exactly the same process as with cars. There are loads of places around that will supply paint at a much more competitive price and quality than halfords. I used to use a company called jr paint supplies up here in sunny Gloucestershire
bmw9818
Fri May 31, 2013 9:48 pm
yeah ive got a mate who will be helping out he knows his stuff, will be thouroughly cleaning/ jetwashing the garage, plastic sheeting all around, got an extractor fan and ducts, mask, eye protection, full body suit and gloves, got an air compressor as well,
got four gas heaters which i hope should be enough to essentially "bake the paint" and cure it so it is touch dry, then il let it sit for about a week until completely dry,
ive been practising on a few panels for a couple of months as well,
only thing that worries me is that the garage isnt big enough for a one off respray, il have to spray one side and the back then let it dry and respray the other side...
scjimbo
Fri May 31, 2013 9:55 pm
Fair play. Well the only thing I would say is, if you cannot get round the whole car in one. Pick a line you can hide the first and second spray in. Ie all except the doors, wing and quarter panel down one side. If not you will have a bastard of a job getting it to match.
Best advice is little and often. And the surface on top is only as good as what's underneath.
There are loads of places about that supply car paint. Google is your friend on that one mate.
G-Bear
Sat Jun 01, 2013 6:52 am
As said, there's plenty of paint factors about. Plus they know their paint, unlike most colleuges at Halfords. Sounds like you're well prepped.
Good luck and post some pics up if you can.. :)
Sat Jun 01, 2013 8:11 am
bmw9818 wrote:yeah ive got a mate who will be helping out he knows his stuff, will be thouroughly cleaning/ jetwashing the garage, plastic sheeting all around, got an extractor fan and ducts, mask, eye protection, full body suit and gloves, got an air compressor as well,
I've seen some excellent home jobs. Good luck.
Be careful with those GAS heaters though!!!!!! :bolt:
Stevevrs
Mon Jun 03, 2013 8:47 am
Metalflake in Chessington should be able to help.
0208 397 6198, they can supply any colour etc.
Steve
bmw9818
Mon Jun 03, 2013 1:24 pm
Yeah il try and attempt to "mist" it in the centre so its easier to match both sides, should be fine I've done a spray on a wing and its come out nice!
Got a lot more to do, loads of little dings and chips, got some welding on the rear valance, dent in rear, going to buy new bumper trim, rubbers, prob new windscreen, sunroofs also rusted allready got a clean one ready to be sprayed,
Will take a couple of before and after pics!
bmw9818
Mon Jun 03, 2013 1:27 pm
Nice one! You've got me curious about the gas heaters now?
bmw9818
Mon Jun 03, 2013 1:29 pm
[quote="Stevevrs"]Metalflake in Chessington should be able to help.
Steve[/quote
I gave them a call actually a decent price! Probably use them
capnmchl
Mon Jun 03, 2013 6:47 pm
Make sure the compressor is drained and as water free as possible before you start. The same with the air hose. And make sure you have a hose that delivers good flow, not one of those horrible plastic spiral ones.
Neilios
Mon Jun 03, 2013 8:10 pm
Water vapour (burning calor or similar produces lots of water)and spread dust by the convection of air, its not great, use electric heat if possible in a garage at home.
