i asked you guys a while back about something draining my battery ever since i done the conversion....
it happend to be my lighter and power antenna...... what a nightmare trying to get it to work without draining the battery but not sure how to get round it unless i put a switch inline to them! ,
what a joke tho....pissing ariel making my battery flat....but then again that is if i leave it standing for 4-5 days!:L x
m52b28 battery drain! , fuse....
If you mean the drain is through the fuse (#28) for the antenna and lighter, the alarm/immobiliser, if you have one, should also be on this fuse, and is a much more likely candidate to be the cause of your problems.
