Fan removal
Francoise
Help needed removing the radiator fan, I have a good 32mm wrench but the water pump is turning as I hit the wrench, what do I do?
bab-91
Stop the belt from moving with a large screw driver,
IG - bab91
IG - bab91
TPS
It needs a shock to free it, its a clockwise thread as well. An 32mm open ended spanner, & a copper Mallet, did it for me.
Francoise
So from the front of the car I need to hit the wrench towards the left of the car, but I still can't stop the water pump from moving, is their a special tool needed?
Rtaylor2208
It's a reverse thread so as TPS says you need to turn it clockwise if you were looking at it from the front. The pump will move but the shock from hitting the spanner with the mallet should get it free.
No other tools are required.
maxfield
It's reverse thread. If you put a spanner on you would need to hit it towards the passenger side of the car, assuming RWD.
For viscous fans I've always found they come undone easier with a hammer and screwdriver.
TPS
It can be a PITA, like installing the rear view mirror!
Francoise
Fans off thanks for the advice
capnmchl
Another trick is to grip the water pump pulley with some pipe grips. Works for me all the time.
Motorhole
Piece of flat bar, a drill and a hacksaw/jigsaw are all you need to make a replica of BMWs special tool for holding the water pump
