lsd diff oil
Wiki says Castrol SAF XJ
http://www.e30zone.net/e30zonewiki/inde ... fferential
Top tip: Make sure you can get the refill plug loose first! Seen many people drain their gearbox or diff and then being unable to refill it again!
Saf-xj doesn't exist any more, it's now castrol syntrax.
Also, neither of those existed when the e30 was made. Castrol racing b373 is about half the price of syntrax, which means you can change it twice as often
cheers,
harry
harry
£14.40 per litre with free delivery from JJC on Ebay
http://www.ebay.co.uk/itm/370739697374? ... 1497.l2649
Just ordered myself a couple.
No it doesn't. As I said earlier its been replaced by castrol syntrax 75w140.SteSE wrote:Yes it does!harry_p wrote:Saf-xj doesn't exist any more
Unless castrols own website is wrong.
http://www.castrol.com/castrol/generica ... Id=7068181
"CASTROL SYNTRAX LIMITED SLIP 75W-140
(previously known as SAF XJ) "
cheers,
harry
harry
- Brianmoooore
It's been replaced, or had it's name changed. Anyone selling it as SAF XJ might just have old stock.
