Advice on spark plugs please!
ultimatime30
Anyone have a preference as the best ones to have?
HJG-E30
I've always found single electrode standard NGK to work best
Mo13
as above NGK
ultimatime30
Are they the copper core ones?
NGK BPR6ES are recommended as being the best for the M20 engine.
jmc330i
Stay away from the multi electrode plugs. I can remember a thread on a Vaux forum about an XE lump that had one of the electrodes bouncing round inside the cylinder, but because there was another electrode making a spark and there was no misfire, the guy didn't realise anything was wrong until the damage was done.
Possibly not a common problem, but something I'd steer clear of anyway.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
This.Speedtouch wrote:NGK BPR6ES are recommended as being the best for the M20 engine.
Has been proven on the rollers more than once that they run better with an NGK than other plugs.
Quaser
what about m50/m52 engines
maybe we should have a wiki on recommended spark plugs for all engine variations
ultimatime30
Can't believe how cheap them NGK plugs are!
Morat
But good quality. Hard to believe eh?
ultimatime30
Absolutely! Almost wish I had a V8 in it now hehe
ultimatime30
Thanks for your replies guys, appreciate it
faze30
NGK ARE THE ONES DUDE
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
reggid
if only the rollers were that repeatable...., a properly calibrated and monitored engine dyno could pick up something perhaps. id like to see something conclusive new plug stock vs new plug BPR6ES (one heat range cooler)B7 wrote:This.Speedtouch wrote:NGK BPR6ES are recommended as being the best for the M20 engine.
in reality there is not going to be any decernable difference between the stock and BPR6ES unless you have a much higher comp lump and if it is not a higher comp lump you could get too many deposits which could be a minor issue long term. ive run BPR6ES and bosch stock ones and ZR5xxx and even BPR5ES it is much of a muchness TBH. ive dyno tested fancy CDI coils systems and they do SFA on a naturally aspirated engine with minor redlimit increase
E30 325is with M20B31
