e30motorwerks skid plate + mason's cross brace
fporro
Post Fri Apr 12, 2013 11:05 pm
Aloha Friday,
Just added Mason's steel crossbrace to my 87 iC, had to remove and do slight modification to e30motorwerks skid plate.
Basically a little trimming and drilled new mounting holes for it to latch onto crossbrace.
They do clear Racing Dynamics headers, mounting hardware includes washers in case you are not utilizing a skid plate.
Little rubber tube near headers is my crank ventilation pipe.
Mason recommended steel for cabrios, others chassis will do fine with aluminum.
Thanks Robert and John for putting out good products. :)
http://www.bimmerfest.com/forums/pictur ... reid=34817
http://www.bimmerfest.com/forums/pictur ... reid=34818
http://www.bimmerfest.com/forums/pictur ... reid=34820
http://www.bimmerfest.com/forums/pictur ... reid=34822
http://www.bimmerfest.com/forums/pictur ... reid=34821
http://www.bimmerfest.com/forums/pictur ... reid=34823
http://www.bimmerfest.com/forums/pictur ... reid=34824
http://www.bimmerfest.com/forums/pictur ... reid=34825
http://www.bimmerfest.com/forums/pictur ... reid=34826
http://www.bimmerfest.com/forums/pictur ... reid=34827
