Mixing engine oils
jimbob29
Can you mix oils of the same grade but with different brand names?i need to top up the mrs oil but wanted to check.the service book said it had 10w 40 synthetic grade but don't no what brand so could get some castrol 10w 40 synthetic and put that in?
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
harry_p
It'll be fine.
cheers,
harry
harry
jimbob29
Thank you
ross_jsy
If you are that worried, give the place that serviced it a call and ask what make they use. Will be ok though
HairyScreech
forget about it.
In theory mixing oils is not a good plan, in practice it happens every day with no issues. Unless your REALLY REALLY unlucky then it will be fine.
Mixing oils is infintely better than not enough oil
Captain_Birdseye
What! why man? You trying to give this guy a job for the weekend or something? He's got a mrs, he doesn't need extra work.zaust wrote:Why not just do an oil and filter change and then you know your topping up with the same.
