brake pedal bouncing back....
SHAKEELE30
- Boost Junkie
what could cause the brake pedal to keep bouncing back when braking, no other lights appear on the speedometer apart from one, think its for the pads....
lhd220turbo
brake pads wouldnt cause that unless you've got big bulges in the disks, more likely to be master cylinder.
try bleeding the brakes and start with a visual inspection of all the braking components looking for any obvious issues
wullie325i
- CAUTION - unreliable trader!
warped disks usually mate.
chh137
Warped disc's or seized calipers or maybe both.
Jesus325iTouring
- Frog freak !
Warped discs and bulged tyres, the later i'm aware of having removed just the thing from my Transit.
