I have a new front ABS sensor wire to replace as one has been damaged.
Does anyone know the correct pin to purchase when fitting a new sensor wire at the ECU end?
I'm sure I've read you can purchase the small silver pins and a tool to remove the old ones.
Replacing ABS wire at ECU
