e30 M3 mirrors - same as other e30s?
DasChin
Wed Mar 20, 2013 9:09 am
looking for a replacement px side casing for the car in diamond black.
would it be same as the other e30s as few for sale on here?
not sure if its a special M casing to basically make you cough up more dough ;-)
thanks, NW
Wed Mar 20, 2013 9:20 am
M3 mirrors are the same as ordinary E30 mirrors, but those for LH drive cars are different from those for RH drive.
harry_p
Wed Mar 20, 2013 4:07 pm
What is the actual difference though?
I'm pretty sure there's enough adjustment in the motors to be able to adjust the mirrors on a rhd e30 to be able to see behind clearly when sat in the passenger seat, and vise versa.
cheers,
harry
Wed Mar 20, 2013 4:40 pm
If you compare a N/S and an O/S mirror you will see that the base plate is different.The difference is reversed on LHD cars. Even fully adjusted, you cannot see properly without moving in your seat.
harry_p
Wed Mar 20, 2013 4:45 pm
curiouser and curiouser. I'm going to have to try it now :mad:
In the absence of being able to get hold of a lhd mirror couldnt you shim behind the motor to add a little more tilt in the desired direction?
cheers,
harry
kundiboy
Fri Mar 22, 2013 7:58 pm
Just swap the mechanism from your LHD mirror and it will be fine. I did this 7 years ago and had no problem.
1988 Diamond Schwartz E30 M3
Sat Mar 23, 2013 10:07 am
kundiboy wrote:Just swap the mechanism from your LHD mirror and it will be fine. I did this 7 years ago and had no problem.
How does that work ? :?
ALL E30 mirrors have exactly the same motor and it is not sided.
Demlotcrew
Sun Mar 24, 2013 1:45 pm
There's a huge difference between LHD and RHD mirror housings, you wont be able to adjust them enough to compensate.
This is a great example.
Notice the difference between the two mirrors.
andyp
True Old Skooler
Sun Mar 24, 2013 1:48 pm
Demlotcrew wrote:There's a huge difference between LHD and RHD mirror housings, you wont be able to adjust them enough to compensate.
is that your new car
nice,
