gents;
where do you buy your light bulbs from for your front fogs, one of mine has blown.
it looks as if they come complete in the bulb holder and wire attached
lightbulbs for front fogs
lhd220turbo
DHFiS
lhd220turbo
unsure, want to get the correct wattage bulb
Rtaylor2208
Standard 55W 12V H3 bulb. DON'T touch the 'glass' with your fingers when fitting.
Also, (assuming these are facelift light), don't crawl under the car to fit them. Remove the plastic plug half way down the glass, unscrew the cross head screw behind, and the whole light comes out forwards.
lhd220turbo
aye, i've already removed the old light.
55w it is then
55w it is then
