Wheels
Jamboree
Post Sat Feb 16, 2013 11:31 pm
I'm looking at getting borbet a wheels 16x9.0 all round will these fit without modification ur thoughts please
j2b
Post Sat Feb 16, 2013 11:42 pm
I think depending on the offset you may need spacers on the front !
I"m sure some one will verify for sure soon .
89 more door 6 pot
BATTS91
Post Sun Feb 17, 2013 12:16 am
I had 16x9 kerscher carmonas i had to use 5mm spacers to clear the front calipers , I also got longer bolts for the front too.
kman82
Post Sun Feb 17, 2013 12:26 pm
I've got borbet b's 9j. I have 3mm spaces on the front.
Jozi
Post Sun Feb 17, 2013 12:32 pm
I think the Borbet A's (B's defo) need a small spacer to clear the front calliper. I also need shorter springs with my BC coilovers :/
kangman
Post Sun Feb 17, 2013 12:46 pm
maybe invest in some adjustable top mounts, so you get a bit of camber at the front as a result the top of the tyre is under the arch
Post Sun Feb 17, 2013 2:13 pm
Text speak and Borbets, who would ever guess ? :)
