mtech 2 clips and bolts set
ibzy
Post Fri Feb 15, 2013 2:03 pm
hi i am after a full set of clips and bolts for a bmw e30 mtech 2 kit if any one has any or knows were to get them from plz get in touch thanks
si911t
Post Fri Feb 15, 2013 2:36 pm
ebay
Jim320i
E30 Zone News / COTM Team
Post Fri Feb 15, 2013 2:40 pm
The dealers prehaps?
G-Bear
Post Fri Feb 15, 2013 2:51 pm
Go onto The Real OEM website get the part numbers and order the from BMW Cotwolds on here for a discounted amount.. Although it may not be that expensive so might work out cheaper to order and collect from your local dealers..
Captain_Birdseye
Post Fri Feb 15, 2013 3:50 pm
Your local bmw garage. They will order them in for you the next day. You will need to know which fixings as all the Part dept. will have is the old PDF file on the computer with a diagram of all the fixings against the parts.
snakebrain
Post Fri Feb 15, 2013 5:42 pm
Have you tried a Nissan dealer? :D
Post Fri Feb 15, 2013 6:03 pm
Two options. Several tubes of Tigerseal or several hundred pounds and your local dealer ! 8O
sunnyr83
Post Sat Feb 16, 2013 11:12 am
£200 for the full set from the dealer. As far as i have read you can't pick and choose the bits you need so have to get the whole lot.
G-Bear
Post Sat Feb 16, 2013 12:59 pm
Christ so much for it being cheap. In that case I'd definately order from Cotswolds on here if I were you. Get all the discount you can.
polsta
Post Sat Feb 16, 2013 2:37 pm
sunnyr83 wrote:£200 for the full set from the dealer. As far as i have read you can't pick and choose the bits you need so have to get the whole lot.
who said that ? 2 weeks ago i bought pretty much every single nut bolt clip and fitting all seperate for a tech 1 to rebuild and re fit all the bumpers,valances,inserts,skirts,door mouldings,re build the rear spoiler, all front and rear end stuff all external parts and trim,plastic under tray and arch liner and wing fittings, plus the bonnet foam and side stripes (which were £80 the pair) and a few other bits, it was £250 the whole lot
polsta
Post Sat Feb 16, 2013 2:43 pm
to to real oem, then select car details, click viehcle trim, its all there, if you just refurb and re use the more expensive parts like the big brackets, it doesnt cost too much
http://www.realoem.com/bmw/showparts.do ... g=51&fg=15
skirts/pods
http://www.realoem.com/bmw/partgrp.do?m ... g=51&fg=20
Captain_Birdseye
Post Sat Feb 16, 2013 5:28 pm
pacerpete wrote:Two options. Several tubes of Tigerseal or several hundred pounds and your local dealer ! 8O
Not entirely true? As much as I respect you Pete... that's bullshit.
sunnyr83
Post Sat Feb 16, 2013 5:46 pm
If you READ what the OP is after, its the Tech 2 clips. He has mentioned nothing else but!
polsta
Post Sat Feb 16, 2013 5:59 pm
IF YOU READ my post and click the fooking links, instead of just sitting on the sunshine bus, you will see it IS TECH 2 !! and available piece by piece
polsta wrote:to to real oem, then select car details, click viehcle trim, its all there, if you just refurb and re use the more expensive parts like the big brackets, it doesnt cost too much
skirts/pods
sunnyr83
Post Sat Feb 16, 2013 6:11 pm
I read a post on here recently, someone paid £200 for the whole kit. I wasn't aware. I do apologise oh mighty 1.
I didn't bother clicking on the links because i couldn't be bothered tbh.
Now could you please explain the sunshine bus comment. What are you on about?
sunnyr83
Post Sat Feb 16, 2013 6:36 pm
Feel free to pm me polsta. Sorry to the OP
No handbags here either. Nothings even been said!!
sunnyr83
Post Sat Feb 16, 2013 6:46 pm
