I want to change the alternator belt on my m42, how do i remove the fan so the belt can gain access to the pulleys??
Can the alternator belt go over the fan without me having to remove it
cheers
How do i remove the fan on a m42
kangman
MY FACEBOOK PAGE- CLASSIC STANCE
http://www.facebook.com/pages/Classic-S ... 6444884427
MY FOUR EYED BEAST
MY FOUR EYED BEAST
age
- Formerly twist316
will pass without taking off the fan.
the fan is reverse threaded and requires a 32mm spanner to open it for future reference
to take the fan off you need a 32mm open ended spanner and a hammer ,give the spanner a hit as if to tighten the nut and it will undo .
+ a yard full of scrap turds
Correct, but there's no need to remove it to change a vee belt. Feed the belt over the fan and onto the water pump pulley first.magpie wrote:to take the fan off you need a 32mm open ended spanner and a hammer ,give the spanner a hit as if to tighten the nut and it will undo .
