Twin mapping an ecu? Sport + eco mode
bmw9818
Post Tue Jan 29, 2013 12:24 pm
Just curious is it possible and if so how difficult would it be to run two maps on a m20 ecu,
A super Eco mode for example, which would restrict throttle input keep revs low etc
And then just a sport type mode?....
Possible?
bigwinn
Post Tue Jan 29, 2013 12:31 pm
could you physically run two ECU on a switch type arrangement?
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
harry_p
Post Tue Jan 29, 2013 12:40 pm
unless you run a drive by wire throttle you're not going to be able to do anything about the amount of throttle input.
i think it would be easier just to moderate the throttle input and revs yourself to save fuel
cheers,
harry
bmw9818
Post Tue Jan 29, 2013 12:42 pm
That's what I was thinking but the wiring would be insane in addition to the car running lumpyish as it learns the new settings?
ross_jsy
Post Tue Jan 29, 2013 12:46 pm
Ant from A-tech used to offer a twin map ECU, I'm guessing it was megasquirt based
Post Tue Jan 29, 2013 1:16 pm
It is possible, by replacing the standard 27C256 EPROM with a 27C512 which has double the capacity and programming it with two maps, and use a switch to toggle between them:
http://qcwo.com/technicaldomain/dual-performance-chips
