disk rear trailing arm
dje30
Post Sat Jan 26, 2013 1:11 pm
I have bought some complete disk rear trailing arms
Arms
Disks
Calipers
Hand brake cables
My only question is how do I go about fitting the hand brake cables as the ones attatched to the arms don't have any plastic covers round them.
Do I feed the cables through my existing ones?
Post Sat Jan 26, 2013 1:43 pm
Ends must have been cut off of the cables, in which case they are scrap.
**BANNED**
Post Sat Jan 26, 2013 1:46 pm
Handbrake cable outer's rust to the guide tube where the cable enters the car.So at a wild guess,your supplier has just un-bolted the cable at the handbrake and pulled the lot through.
I am not sure what the difference is between disc brake h/b cables and drum brake h/b cables,if any,but a hunt through one of the online parts lists will tell you if the part has the same number.
TBO,if it were me,I would fit a pair of nice new cables anyway!
Youth is wasted on the young.
dje30
Post Sat Jan 26, 2013 3:40 pm
I'll try and get some pictures up later
I have to renew the disks and pads so maybe new handbrake cables isn't a bad shout
Another question I forgot to add was I just bought an e46 rack
What ujs ect is best too use?
Post Sat Jan 26, 2013 8:01 pm
daimlerman wrote:Handbrake cable outer's rust to the guide tube where the cable enters the car.So at a wild guess,your supplier has just un-bolted the cable at the handbrake and pulled the lot through.
Cables are different at the hub end, so can't be interchanged.
There is a four inch threaded section attached to the frond end of the inner cables, and there's no way you can get that to pull through the outers!
