BOGE product in Lemforder Box - Am I going MAD!!!!
PG325
Post Sat Jan 19, 2013 10:21 am
I've just bought a couple of E46 Cab rear shock top mounts from a well known parts supplier, I wanted OEM and specified Lemforder, however both mounts are stamped BOGE.
Are these two companies linked in anyway or has the supplier swapped the brands in the box?
Post Sat Jan 19, 2013 10:29 am
whats the problem? both excellent OE manufacturers
maxfield
Post Sat Jan 19, 2013 10:38 am
Fairly certain they're part of the same company.
PG325
Post Sat Jan 19, 2013 10:41 am
Simon13 wrote:whats the problem? both excellent OE manufacturers
I know both are OEM but its like opening your new Sony TV box and finding a Panasonic inside, probably just as good but not what you ordered!
Surely BOGE should have come in a BOGE box.
Post Sat Jan 19, 2013 10:54 am
more to life than worrying about this imo
Meatballs82
Post Sat Jan 19, 2013 11:02 am
Boge and Lemforder are both part of the ZF group.
In the second pic you can see at the bottom it looks like its been dremelled, they've prob just scrubbed the wrong logo off (Lemforder logo is a triangle). It will be the same part either way, get it fitted! :D
Andyboy
Alpina Colada
Post Sat Jan 19, 2013 1:29 pm
That'll be 'BMW' they've taken off. Common on Lemforder suspension bits like wishbones. BMW parts but with the BMW logo taken off and sold in a different box for a third of the price.
Sanchez
Post Sat Jan 19, 2013 1:53 pm
As above.
My dad bought a rear beam bush from BMW.
Then bought one from ECP.(Lemforder)
Both parts same logos, numbers, and looked very much like they can out the same mould but the Lemforder one had the BMW rondel ground off.
Meatballs82
Post Sat Jan 19, 2013 1:58 pm
Sanchez wrote: same logos, numbers, and looked very much like they can out the same mould but the Lemforder one had the BMW rondel ground off.
Correct, as Andyboy stated the only noticeable difference is the price!
irish320i
Post Sat Jan 19, 2013 2:04 pm
get a lot of this with intermotor electrical parts. Its nice when you open the box and you see its genuine.
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
chh137
Post Sat Jan 19, 2013 2:08 pm
Box engineering, goes on all the time, Clutch and brake components are biggest culprits.
**BANNED**
Post Sat Jan 19, 2013 4:39 pm
Bet a fiver the OP wears Calvin Kline underwear,Primark is just as effective at catching the dribbles.... :D
Youth is wasted on the young.
capnmchl
Post Sat Jan 19, 2013 6:12 pm
I'd rather have the panasonic.
But to keep it on track. Common practice.
Happens a lot with cambelt kits. You might buy a SKF cambelt kit, which has a Gates belt and tensioner and idler bearing. Also with clutch kits. What you think is a cheap clutch is actually an LUK or Valeo.
However, I did buy a Lemforder prop donught from carparts4less a while ago which was in a battered box and the donught was definately not lemforder but some cheap underbranded piece of crap. But that was more likely someone buying it, putting a cheap one back in the box and sending it back for refund.
As said though, both lemforder and boge are quality oem manufacturers, so there's nothing to complain about.
