M3 Wheel fitment? (Wheels on - with Pics ;-) )
Hi
Quick question, will the below fit an M3. Thinking of buying a second set of wheels
front 8.5 x 17" OFFSET - E14
Back 10 x 17" OFFSET - E28
ET is 20 or thereabouts for an M3, I think..
They should be ok, but you might need to be carefull with your tyre choice, and you won't know if they'll clear the front brakes until you try them on. The calliper sits quite forward in the wheel on m3s.
Rears might need a small spacer.
cheers,
harry
harry
- Kos
- Contact:
I've run 8.5 x 17 et13 & 10 x 17 et20 on my m3
One set was borert C's and they cleared the brakes with lots space
My MK morltorsports are the same size & et and also clear
However depending how low the car is, 10j on the back with 245 35's needed arch rolling
235 40's may have cleared but it's a stretch
Personally I think 8's & 9's with with 215/40 and 235/40 is perfect
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
Hi
Ok so i got the wheels, only tried on the back wheel today..... It didn't fit
it's scraping the spring mount on the inside, I'm gona try a 10mm spacer tomorrow to see if the clears it. currently its ET28 so will make it ET18.
By doing this I’m worried its going to bring out the wheel, so start scrapping the arch (they are rolled in, so hopefully not).
Has anyone else had this prob, is anyone got 10 x 17" OFFSET - E28 ???
I found this online, it's been very helpful.
http://www.rimsntires.com/specs.jsp
thanks
thanks
Hi All,
So i finally got around getting the wheels on and they fit without srubbing
I had to put 6mm spacers at the front (to clear the calipers) and 8mm spacers at the rear.
these are Alpina rims of a b12
anyway check them out
325i Sport Tech 1 - R.I.P
E30 addict.
E30 addict.
Those dont look too bad at all
Sweet looking, but how do they ride at speed - any vibrations going on?
- Kos
- Contact:
That does look
IG Pukar.Designs
IG Pukar.Designs
Very cool!
virdi325i wrote:At the front i've got 215-40-17 and at the rear 245-35-17
I did it for the same reason, needed a change from the BBS Style 5's
