Demlotcrew wrote:Here are two heads side by side.
The casting is also different, the 215hb heads offers the option of running larger valves as they are very slightly further spaced apart, this is also true for the cam box tappet spacing between the 'early' and 'late' engines. The early 195hp heads have 26mm ports and the later 215hp heads have 28mm ports. You can most certainly port out a 195hp head to 215hp spec.
You would also be shocked at the fuel and ignition maps between the two heads, a 195hp engine wont even idle with a 215hp ecu.
Andrew
Andrew thank you , for help,
so from what i understand , the valves are the same size ,
all i have to do is bore the inlet ports out a bit , and it shouldn't cost me 1,5 grand , the inlet valve size the same,
the reason i strarted this thread is , in case i ever need to change cylinder head on my M , all i have to do is buy 195 bhp head. and save a lot of money.
by the way , retrimmed my interior , some time ago,
she had respray as well , few weeks ago too,
