15" steelies
Jos
Post Fri Dec 14, 2012 3:04 pm
Anyone know if there is a 15" steelie with the correct PCD/ET for the e30 off a vdub or something like that? Even something smaller that could be lathe'd out would do :)
Looking for a set of winter rimz, after some tyre research it appears that 195/65/15 is about the cheapest size (slightly too big for the e30 but not significant enough to bother me)
'94 e36 tree climber
Jos
Post Fri Dec 14, 2012 3:07 pm
nm found them, funny how you spend 2 hours looking with no luck and then boom, there it is..
VW OEM Corrado steel wheel 15x6 57.1 ET35
and the Mini...
Jos
Post Fri Dec 14, 2012 3:13 pm
14" limits tyre choice a bit, no WinterContact T850 in 14" afaik
