Mtech 2 body kit clips
verde
Are these NLA or can they be bought new? Either way i need a set of them. I only need the ones for the side skirts as a couple are fecked.
Raise hell praise Dale.
All available and every clip fitting and template to do the job PROPERLY is well over £200!
A couple of the templates are NLA though.
steve_k
got any part numbers barry??
like euan i need a few new one's for my side skirts as a few have gone missing over the years also the gasketthat sits between the side skirt & the sill,
euan sorry for the thread hijack.
BenHar
steve_k
cheers dudeBenHar wrote:Part numbers should all be here:
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
Ben
maggspower
- Turbo Farmer Tractor Driver
I can confirm the above, a customer of mine has just ordered thembss325i wrote:All available and every clip fitting and template to do the job PROPERLY is well over £200!
Do you know which templates are NLA Barry, as I have to fit the skirts and pods and the templates are being ordered this coming week.
verde
Mother fucker I thought this was gunna be like 60-70 quid max. Faaaaack, well like steve i only need a few so hopefully it aint too much
Last week i fitted a full kit to a 4dr and the only templates that were available were the N/S sill, both front wings, front valence and N/S rear quarter.maggspower wrote:I can confirm the above, a customer of mine has just ordered thembss325i wrote:All available and every clip fitting and template to do the job PROPERLY is well over £200!
A couple of the templates are NLA though.![]()
I think i may have grabbed the last rear quarter one.
I have a load of left over clips as some cam in quantities of 10.
maggspower
Thanks. If push came to shove could you use a N/S template on the O/S if you turned it over, as surely they are just a mirror image?bss325i wrote:Last week i fitted a full kit to a 4dr and the only templates that were available were the N/S sill, both front wings, front valence and N/S rear quarter.maggspower wrote:I can confirm the above, a customer of mine has just ordered thembss325i wrote:All available and every clip fitting and template to do the job PROPERLY is well over £200!
Never fitted skirts and pods to a non kitted car. Hence the question
I had to cut the N/S one up to do the O/S but that was on a 4dr. I have done a 2dr in the past but had both templates so couldnt say if its possible but im sure with a bit of messing about it could be done.
