Tell me about the 1.8 8v?
baxter-e30
Post Tue Nov 13, 2012 9:17 pm
i believe mines the 115bhp model, if thats right.
can i get peoples views on them..
i know it would probably be a waste of money but is there any power that can be squeezed out of them?
cheers for any advice :)
TPS
Post Tue Nov 13, 2012 9:22 pm
Yours is the M40, its a capable engine, simple to work on.
The only power gain I can think of, is to make sure its serviced properly!
Post Tue Nov 13, 2012 9:35 pm
get it in tip top condition first, good service, rebuild the head if its fooked and noisey, luckly there are plenty of aftermarket camshaft/lifter kits. stick on a new Rotor arm and Dissy cap whilst your at it. Also worth getting your injectors reconditioned. (ive got a set allready done if your interested)
Then look at high lift cam, chip and lightened flywheel, then stick a 4.45 diff on.
Kent cams, Piper cams and diblias all do aftermarket camshafts for them.
You can get chips easy enough for them on ebay and the like. if you have the 380 cat ecu after market chips are hard to get hold of, i bought one once and it ran like a dog and the seller didnt want to know. Ive managed to find another supplied from germany and ive yet to try it out.
Flywheels again can be found around the net if you look
Wont be the fastest thing on the planet and wont return very good bang per buck however but should be fun for what it is.
If your not hell bend on keeping the original engine you could drop an m42 in however again most m42's are worn out with rattly timing gear and spent most there life revving there tits off by young drivers (Speaking from experience :D )
Also your best sorting all the suspension out first, i had a 325i touring with 280k on the clock that was very very tired and was scary in corners. i have a 318i touring auto with 50k on the clock and i can throw that in corners at way quicker speeds than any other e30s ive owned and handles superbly.
baxter-e30
Post Tue Nov 13, 2012 9:39 pm
Alex wrote:get it in tip top condition first, good service, rebuild the head if its fooked and noisey, luckly there are plenty of aftermarket camshaft/lifter kits. stick on a new Rotor arm and Dissy cap whilst your at it.
mines 165k, drives like new. fk shocks and springs, front and rear strut braces. drives superb..
could you point me in the right direction towards cams & such, not having much luck finding anything..
Post Tue Nov 13, 2012 9:43 pm
Search car - Engine Tuning - Cams
http://www.motorsportworld.co.uk/frame- ... t-cams.htm
http://www.ebay.co.uk/itm/BMW-E30-318i- ... 2a25db2d73
http://www.jbracing.com/flywheel-bmw3.php
The above flywheel is bolt on however, you your probably best taking a used one to a machine shop
baxter-e30
Post Tue Nov 13, 2012 9:49 pm
yeah i know a place in leeds that lightens & balances them at a decent price, could be worth a go!
cheers bud!
Post Tue Nov 13, 2012 9:50 pm
Or drop an M30/M50/M52 Engine in :D
baxter-e30
Post Wed Nov 14, 2012 6:27 pm
Alex wrote:Or drop an M30/M50/M52 Engine in :D
would that cost much?
Post Wed Nov 14, 2012 6:35 pm
M30 would be cheaper as you dont have to move the servo, make complex exhuast manifolds etc and wiring is a piece of piss. i recon you could do m30 for well under £500 M52 would be £700 do do it properly with dan-the bits
