Prefacelift rear bumper
polsta
Post Fri Nov 02, 2012 3:37 pm
Need a bit of help here
rear metal bumper pre facelift- ive had the bumper blasted and powder coated, the bolts that joined the 3 sections would not un-do, so had to cut them off , so i need new bolts
part number 6, here, how many of 6 do i need ? as it shows 2 on the left, 1 on the right ??? yert says x6 in the qualntity but im sure there isnt 6 on the bumper ???
would i get the nut with them ? or is that number 7 ? , its a little un clear
http://www.realoem.com/bmw/showparts.do ... g=51&fg=15
also, parts- 15, 16 , what are they ? and how many are there needd ? - it lists 2 part numbers for each of 15 and 16 ???
basicly trying to work out what parts to re-new here and how many of each i need ??? :mad:
polsta
Post Fri Nov 02, 2012 3:49 pm
whats part 26 ?
26 Set mounting parts 1 09/1987 51129057084 $20.02 Cat=No
does that mean its a full set of mounting parts ??
polsta
Post Fri Nov 02, 2012 3:56 pm
would it be (feel free to add to/edit this list)
bumper-
6) x 6 = 51121843029
7) x6 = 51117070183
15)x2 = 51111900386
16)x2 = 07119916967
bracket-
10)x4 = 51121886299
11)x4 = 07147134319
19)x4 = 51121911293
insert-
9) x? = 51111867927
24)x2 =23112322368
22)x2 = 34414045712
20)x2 = 07119913477
21)x2 = 07119936425
18)x2 = 16121176779 ?
17)x2 = 07119916975
how many of part 9 , clamp, will i need ? it doesnt say ?
clipper
Post Fri Nov 02, 2012 3:57 pm
To join the sections you need 4 bolts (6) and 4 nuts (7).
The other 2 of each are to bolt the center section to the mounts.
15 & 16 are the mounts for the side sections. The bolts go through the wings from inside the boot. Don't know why there are so many part numbers for them though.
polsta
Post Fri Nov 02, 2012 4:01 pm
ok thanks, its a bit un clear, how many part 9, are there ?
im buying as many new fittings for the car re build as possible
got a s**t load on a list, im going to print off, go in bmw and order them all - then its going to be a nightmare on the re build with all these packets and trying to make sense of them all whats for what 8O
clipper
Post Fri Nov 02, 2012 4:09 pm
Can't tell you what 26 will include.
Number 9s from memory, there are about 18 of them but the only sure way is to count the slots in the metalwork.
polsta
Post Fri Nov 02, 2012 4:17 pm
ok thanks, il count them when i get the bumper back, unless anyone knows off hand ?
part 26- trouble is, ring bmw, theyl have no idea , i may ring up and order it over phone, see if i can avoid paying on the phone, then just going to see when its in
Kedge
Post Fri Nov 02, 2012 4:23 pm
That's not the best diagram/list really.
Here's what I think you need;
polsta wrote:
bumper-
6) x8 = 51121843029
7) x8 = 51117070183
15)x2 = 51111900386
16)x2 = 07119916967
bracket-
6) x2 = 51121843029
10)x4 = 51121886299
11)x6 = 07147134319
19)x4 = 51121911293
insert-
9) x? = 51111867927
24)x2 =23112322368
22)x2 = 34414045712
20)x2 = 07119913477
21)x2 = 07119936425
18)x2 = 16121176779
17)x2 = 07119916975
For #9 just count the number of holes in the bumper, from that pic I'm guessing you need 12. Without looking at my car I'm not 100% on the bracket, not sure why it shows one stud has different nuts to the other, maybe some are on the outside of the boot, I can't remember.
Instagram - Kedge85
polsta
Post Fri Nov 02, 2012 4:30 pm
it is confusing, although your saying a total of 10, of part 6 ?
Kedge
Post Fri Nov 02, 2012 4:35 pm
Yea, one for each mount, then four for attaching both bumper corners, two go through the top of the bumper which are covered by the cover plates then each cover plate is held by one.
Instagram - Kedge85
polsta
Post Fri Nov 02, 2012 4:56 pm
no i think- there are just 2 at each end, 1 in the top , and 1 in the central- meaning 2 for each corner piece, i think ?
Kedge
Post Fri Nov 02, 2012 5:12 pm
Yea, that's what I was saying. I mis-typed 8 instead of 4 for part 6. Looked at the diagram properly now and it's pretty simple actually.
Only thing I'd change from you original list is you want 2 number 18s, not 1. Then I'd say you only need 4 number 11s, can't see anything that the other 2 would be used for. Thought like you say, just speak to the dealer and ask what is in the fitting kit.
Instagram - Kedge85
polsta
Post Fri Nov 02, 2012 5:27 pm
ok list edited, think that l do it ?
this cars going to be unreal, expensive, but unreal
when you start looking at things lke this- that list above, plus bead blasting,powder coating, then final paint coat- just for the rear bumper alone 8O
ive got bigger lists of part numbers for things like the valances, skirts, rear panel,front panel,arch liners,under tray, door mouldings, rear spoiler, head lights, plus things like all new roundels/badges, new kidney grille, might get a whole brand new front grille for good measure
ive had the black head light casings powder coated, all new fittings , things like that, will make it a lovely car, although il probably shite myself when one day i total up the grand bill for the job 8O
Kedge
Post Fri Nov 02, 2012 8:18 pm
I'm in the same boat, all my reciepts get chucked in the garage or under the stairs at best. I don't want to know what's been spent on it and never will!
Instagram - Kedge85
gaszman
Post Sat Nov 03, 2012 10:10 am
be lucky if you get them from the local dealer as i got the las in the uk when i did front and rear bumpers mate
