My electric sunroof switch stays on..
kangman
Post Thu Nov 01, 2012 11:49 pm
every time i turn my car off and even press the e/w kill switch, the sunroof switch remains illuminated and still works. how do i fix this?
advice would be appreciated :D
Post Fri Nov 02, 2012 6:33 am
It will work with the doors open even with no key in the ignition IIRC - same as the windows
kangman
Post Fri Nov 02, 2012 8:17 am
windows stop working when i hit the kill switch but the sunroof still works also the switch is still illuminated.
even when i get out the car and lock it the switch is still lit
Post Fri Nov 02, 2012 9:23 am
IT IS NOT A 'KILL' SWITCH, or a 'switch' of any kind. This part is a resettable slow acting 'fuse', and should only be pressed when it has tripped. It also works on the windows only - nothing to do with the roof.
Are the window switches lit as well as the roof switch after the car is parked?
kangman
Post Fri Nov 02, 2012 10:26 am
ohh really i always put the 'fuse' on the off position every time i exit the car, dont ask me why just habit. Ill stop doing it that from now on..
No its just the sunroof switch that stays lit
Post Fri Nov 02, 2012 7:09 pm
If the sunroof switch stays lit and the windows switch doesn't (with the thermal cut out in the 'on' position), then it looks like someone has been playing with the wiring. The sunroof uses exactly the same supply as the windows.
Any evidence that the sunroof is a manual to electric conversion? There are websites where you can get the original spec. of your car from the VIN, or BMW can supply the info. on request.
kangman
Post Wed Nov 07, 2012 9:36 am
S199A AUSSTATTUNG BLEIHALTIGER KRAFTSTOFF without catalytic converter
S215A SERVOLENKUNG, DREHZAHLABHAENGIG Power steering, engine-speed-dependent
S350A WAERMESCHUTZGLAS GRUEN, RUNDUM Therm.insulat.glass green
S401A SCHIEBE-HEBEDACH, ELEKTRISCH Lift-up-and-slide-back sunroof, electric
S410A FENSTERHEBER, ELEKTRISCH VORN Window lifts, electric, front
S428A WARNDREIECK Warning triangle and first aid kit
S546A DREHZAHLMESSER Revolution counter
L812A ENGLAND/IRLAND AUSFUEHRUNG NATIONAL VERSION GREAT BRITAIN
S850A ZUSAETZL. TANKFUELLUNG EXPORT Additional Export tank filling
S925A VERSANDSCHUTZPAKET Dispatch protection pack
I got an electric sunroof from factory, when i have the thermal cut out switch 'off' the window switches are lit and have power, is that normal? and when i put it in the 'on' position they are not lit and dont have power
Post Wed Nov 07, 2012 9:57 am
The window switches are lit as well, with the ignition off and the doors closed, and the roof and windows still work?
If so, pull out fuse #28 and confirm that this kills the lights and motors.
Don't touch or investigate anything else at this point.
Post Wed Nov 07, 2012 10:17 am
Press the cut out in, and NEVER touch it again! It's not a switch.
kangman
Post Sat Nov 10, 2012 1:30 pm
removed fuse #28, and i can confirm it kills the lights and motors
Post Sat Nov 10, 2012 2:04 pm
Open one front door and push in the pin switch in the A pillar. If this makes the lights go out, check that the plastic button in the door frame that operates the switch hasn't gone AWOL.
