Covertible Door Cards
Gavla
So I purchased convertible door cards for £20. Bargain!
All was well until I fit the drivers side, it fits fine except there is a "cut out" where the door pin comes through.
This means that there is a gap of about 2 inches long and half an inch between the window rubber and the door card.
Any ideas why?
Any ideas why?
Rich320I
a factory cut out, or someones cut a hole?
Gavla
They are both identical, if it was a factory cut out why?
Is there a difference between pre-facelift and facelift door convertible door cards?
- **BANNED**
Reads like the driver's door card is a saloon item.
Youth is wasted on the young.
That looks like it has been 'modded' to fit a 2 door saloon, council stylee
Gavla
The passenger side has exactly the same section missing. to be honest does not look like a DIY cut out. Anyway, at £10 per door card I should have known it was too good to be true. Oh well, the search for a decent drivers card continues.
It definately looks 'home brew' to me.
Gavla
I replaced the original vinyl with my cardinal red vinyl. The reason was my drivers side card was completely wrecked.
Yes, I guess I could do a repair, but I think I would rather find a decent door card and cover it again or even try fabricating one out of carbon fiber sheeting?
Foook me, there goes a flying pig with a pair of cardinal red door cards in his trotters !
- E30 Zone Meets/Events Team
I have some Blue convertible doorcads if your after a set.
Admit it Rav, all this talk of pigs got you hungry you cooont !Rav335uk wrote:I have some Blue convertible doorcads if your after a set.
Gavla
tRav335uk wrote:I have some Blue convertible doorcads if your after a set.
Just need the drivers side Rav as the passenger side is fine, I know it is not worth your while splitting the pair though.
Ideally I wanted to keep the original cardinal vinyl but am now considering the idea of getting beige ones and dying them cardinal. Did you not organise this for matt86 on here?
Duke137
Gavla I sent you a pm
You should know the difference by now you Southern hemisphere Shiela!pacerpete wrote:Admit it Rav, all this talk of pigs got you hungry you cooont !Rav335uk wrote:I have some Blue convertible doorcads if your after a set.
Yep, I organised that for Matt.Gavla wrote:tRav335uk wrote:I have some Blue convertible doorcads if your after a set.
let me know if you want them anyway.
