Sparks changed: two oily, two dry...why?
BEERBOY123
Post Fri Oct 19, 2012 8:14 pm
As above, not strictly a technical problem as the car is running well, but why is this?
It's a 1990 iS; the two sparks nearest the front were quite oily, the ones nearest the bulkhead were dry.
Just wondering if this means anything to anyone...
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
mark_i
Post Fri Oct 19, 2012 8:22 pm
if you mean the ouside of the plugs... that would be the rubber rings that seal the rocker cover are leaking
johnl320
Oily on the tips or ceramic part? If it is the ceramic part then your rocker cover gasket could be weeping down the plug holes
johnl320
Post Fri Oct 19, 2012 8:23 pm
Tooooo slow
Post Fri Oct 19, 2012 8:43 pm
johnl320 wrote:Tooooo slow
Don't worry John, we know :D :wink:
johnl320
Post Fri Oct 19, 2012 10:22 pm
Fellow anchor owner :wink:
Post Fri Oct 19, 2012 10:32 pm
