m30b35 inlet manifold gaskets
wixsy
Post Fri Oct 19, 2012 8:00 pm
changing the inlet manifold, have the gaskets but to i bolt them up dry, lightly oil, lightly grease? just need to know as i want to put it all back together tomorrow
zaust
Zone day release
Post Fri Oct 19, 2012 9:07 pm
dry and make sure your surfaces are clean.
M30 Tech 1 Touring on gas.
wixsy
Post Fri Oct 19, 2012 9:17 pm
thanks :D
zaust
Zone day release
Post Sat Oct 20, 2012 8:05 am
If you want you could put a smidge go blue seal on but I never do.
Silverfang
Post Sat Oct 20, 2012 1:20 pm
I tend to use a very very thin smear of blue hylomar to make sure of a positive seal.
When I say thin, as in as thin as you can smear with a finger on the gasket, always worked and means positive seals every time. Also a good idea for the thermostat housing and water pump seals.
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
