my car has been mis-firing in the morning. the engine turns but misses. when the car eventually starts it jerks and jars.
what is the reason, is it the starter motor or do i need the air or fuel filter changing?
misfiring
j2b
air leak, cold start injector/valve , plugs/ leads , split in the dizzy cap , rotor .both new air and fuel filter will help, some will probably have had this and will have more of an idea .
89 more door 6 pot
Grrrmachine
- E30 Zone Wiki / Team Member
Knowing what engine you have helps a lot when diagnosing problems
ameetgill1
i have a 2.5 cab i changed the plugs last week
