15's or 16's???
s13b
Guess its all down to personal preference but im trying to decide what size to go... Any pics to influence my decision either way would be appreciated, even open to a 15 / 16 stagger setup...
Green
I think Hartge's in 16" that look pretty damn sweet.
What sort of suspension do you have, standard, m tech, lowered, holy sheet there's a cat's eye in my footwell etc etc?
That also can help sway a decision
BATTS91
Personally if staggered 16"s.
So happens i took out a cats eye with my exhaust not so long ago lol
bad choice of custom centre box and lowness
s13b
Im running (or going to be soon) on Gaz coilovers, so low...
Well not cats eye low as my old car was like that and its a PITA for a daily. Probably going to end up with ~50mm drop from standard. Not worried about rolling / flaring arches either.
Pics would be good!!!
emdog16
You can get more rubber down with 16's...
Avid E30 Nut, and Scientist of all things that go BOiiiNGGGG.
If you want to go mental on your shocks... check out ForRacingUseOnly.com
poolnoodle
16s look the best IMO but nothing bigger.
15s probably cheaper for wheels and tyres
My chromie on Z1 16s and Toyo Proxes
boomerm20
I find 15" wheels offer the best handling,but 16" wheels look the best.
16" Hartges
16" Hartges
Duke137
I have DanThe's old powdercoated BBS 15" and I love 'em on my car, so much so that I am thinking of selling my 16" Hartges!
oldroydsr4
If your interested in stance etc etc Go for 16's , this will close the arch gap but retain your sump to floor clearance
Cotty
- Hartge Crew
Stance?oldroydsr4 wrote:If your interested in stance etc etc Go for 16's , this will close the arch gap but retain your sump to floor clearance
15" Hartge with 60/40 drop
mikelat
No you don't you just get a different shaped contact patch but the contact area is always the same (car weight and inflation pressure constant).emdog16 wrote:You can get more rubber down with 16's...
1990 325i Coupe Gletscherblau_Metallic
mikelat
And contact area is nothing to do with grip!mikelat wrote:No you don't you just get a different shaped contact patch but the contact area is always the same (car weight and inflation pressure constant).emdog16 wrote:You can get more rubber down with 16's...
capnmchl
16's for the looks, 15's for the comfort.
That's mine on 16" Borbet T's
Same car on 15" AC schnitzers
