hi guys..and girls,
just after a bit of info please..
I will be servicing the "is" this week.please can you tell the best plugs to use and oil??....also is "wynns engine flush"any good if so how do i use it???
thanks in advance..
318is service......
polsta
i always used wynnes fuel injection cleaner in mine and never had any problems
also get some carb cleaner- clean the icv, throttle assembly, and inlet out with it, is real good to do
diff oil change, pas fluid flush and change, brake fluid change, a full coolant flush and change, are all good to do, particularly if you dont know when last done
use quality diesel oil for 3k miles instead of engine flush,
anything Wynnes is all in the mind !
+ a yard full of scrap turds
