Bmw 325i sport on ebay
Stryder
Hi found this on ebay and was looking at viewing it over the weekend, does anyone on this site own this? Im not very technical minded and it seems to be priced fairly cheap?
http://www.ebay.co.uk/itm/BMW-E30-325-I ... 1743wt_922
It will be rubbish, the wheels and the 'stance' tell you everything you need to know
polsta
bubbling on the rear arches- probable that it needs new rear inner and outer rear arches, but then again most e30s need or have had them doing especialy tech 1s
sweep
Looks mint
EFApacerpete wrote:It will be rubbish, the wheels, the 'stance' and the location tell you everything you need to know
fearlessphil
i think it look jonny sound! My touring is lowered and im gunna get 17" pina reps coz i cant afford origonal 16"pinas an mine is probably in slightly worse condition than that yet i would still want similar money
'stance' my arse!
have a look check the history matches the car an if all is well after a test drive get it!
'stance' my arse!
polsta
e30+17" wheels+dropped to the ground= a crap drive
fearlessphil
even if it has uprated suspension?polsta wrote:e30+17" wheels+dropped to the ground= a crap drive
Cloggy Saint
bab-91
Get it bought!
IG - bab91
IG - bab91
fearlessphil wrote:i think it look jonny sound! My touring is lowered and im gunna get 17" pina reps coz i cant afford origonal 16"pinas an mine is probably in slightly worse condition than that yet i would still want similar money
'stance' my arse!
You sir have just made my point better than I ever could !
polsta
by what way do you mean uprated ?fearlessphil wrote:even if it has uprated suspension?polsta wrote:e30+17" wheels+dropped to the ground= a crap drive
Stryder
I was planning on replacing the suspension and wheels once I've bought the car, is there any common faults to look out for?polsta wrote:e30+17" wheels+dropped to the ground= a crap drive
harry_p
it's already had the rear quarters painted, theyre a shade darker than the doors / front wings and has a dubious coach line down the length of the car.polsta wrote:bubbling on the rear arches- probable that it needs new rear inner and outer rear arches, but then again most e30s need or have had them doing especialy tech 1s
so if its got bubbling arches again you can bet there's a mountain of filler in there.
cheers,
harry
harry
fearlessphil
it has bilstine b8 front and rear dampers with 30mm apex lowering springspolsta wrote:by what way do you mean uprated ?fearlessphil wrote:even if it has uprated suspension?polsta wrote:e30+17" wheels+dropped to the ground= a crap drive
polsta
i saw that darker quarter too, like you say a previous crash/prang repair, or bodge repair attempt to halt the arches/cover up rust/bubbling instead of new arches , thats now comming back and he wants shot of it
coupled with probable rusty bottoms of wings, will more than likley mean new rear inner and outer arches , wings, both sides re painted , and a good look inside the boot and rear panel-
polsta
that said- tech 1s in a few years will be a very rare beast , is it better to buy one for cheap and do the work properly, or buy one for more- not really knowing (as most/near all tech 1s need or have had new rear arches and rear panels,wings and more) the real state of it and if its had them done to what standard and maybe have things come back after a year of owning and then having to fork out for stuff
better the devil you know i say
heres a question - rarety and a lot of them being broken/not saved and in say 3-5 years time, how much do you think a very nice restored and fully sorted tech 1 will be commanding price wise ? in that same time period also tech 2s will be that bit older that tech 1s are now and maybe being broken a lot more/needing restoring ?
Stryder
Yep just found out its a cat c so will avoid..polsta wrote:i saw that darker quarter too, like you say a previous crash/prang repair, or bodge repair attempt to halt the arches/cover up rust/bubbling instead of new arches , thats now comming back and he wants shot of it
Stryder wrote:Yep just found out its a cat c so will avoid..polsta wrote:i saw that darker quarter too, like you say a previous crash/prang repair, or bodge repair attempt to halt the arches/cover up rust/bubbling instead of new arches , thats now comming back and he wants shot of it
That will be the least of its problems........
