Wheres the best/cheapest place to get a black kidney grille from?
Thanks.
Black kidney grille
e30-320i
halford couple of quid for black spray and a bit of sandpaper
89 325i touring
Steviec
Is it easy to take the chrome part off to spray then?
e30-320i
it just unclips mate i just sanded mine enough to take the shine off its been on over 6 months and hasnt flaked or chipped
89 325i touring
Rich_W
Do you mean that the Chrome bit unclips separately or do you remove the whole middle section with the upright grilles in?
jonbuoy
The kidney grill come's out mate, the rest stay's there.Rich_W wrote:Do you mean that the Chrome bit unclips separately or do you remove the whole middle section with the upright grilles in?
I did'nt even sand mine down, just used grey primar (Filler) for the thickness from chip's and then Satin Black, look's the nut's
Moofles
it's a lot easier to remove the whole middle section including the vertical sections, then remove the chrome grille from these when off the car...
'08 GSX-R750, '02 CBR600F, and a beast of a Focus 1.8LX...
My old sig
- http://img52.imageshack.us/img52/2652/funnyface8eg.gif
My old sig
psychochild187
i took mine off without the rest . 2 clips only if i remember pop the bonnet and a few seconds later i was done!!
Steviec
Sorry, I meant is it easy to seperate the chrome part of the kidney grill from the rest of it.
psychochild187
yeh there just a 3 part grill thing the center bit you want to paint black is clipped in and slots into the other 2 sides . easy .
Moofles
those 2 clips hold the grille/vertical slats piece on though, at least on my old one - you took two clips off the top (just under the lip of the bonnet) and then the bottom of the chrome grille/vertical slats section just comes out of it's positioning holes. But then you still need to take the chrome grille off the vertical slats, which was more fiddly at least on mine.psychochild187 wrote:i took mine off without the rest . 2 clips only if i remember pop the bonnet and a few seconds later i was done!!
Best bet is to just try it and see what's easiest for you! it will only take a minute to decide!
My old sig
My old sig
