Need build ideas
craigd
Post Wed Aug 29, 2012 7:19 pm
Im building a 4 door e30 (currently m20b25) and want to run 300whp and turbo converted.
What would you guys recommend as being the easiest way to achieve this on a budget.
The options ive looked into already include:
1. m20b25 turbo'd with other parts uprated and standalone ecu to run it
2 m50b25 turbo'd again with other parts uprated as above to get the necessary power
3. s50b30 turbo'd with standalone ecu
Looking to build a car that is reliable enough to be used as a daily drive and also dont want to be drinking fuel all the time, so ideally dont want to be stretching the engine to its full capabilities to reach the 300whp mark, would like it to run it comfortably, so that if required in the future, more power can be gained without having to start from scratch. Obviously my pockets arent endless but i can get each of the donor engines for around the same cost as i will buy a complete car to break for parts resulting in a low cost engine whatever the choice. but i am aware that using the m50 / s50 lumps will require the additional conversion parts before i can get started on tuning.
any ideas will be welcome along with what parts i would need to uprate to get the necessary power
cheers
leeparkes
Post Wed Aug 29, 2012 10:54 pm
Id go M50 turbo for best bang per buck, ive read they can run up to 300hp on standard management.
e30den
Post Thu Aug 30, 2012 6:40 pm
It maybe cheaper to buy one thats already been done, there are a few on
here for sale at the moment, may save you a lot of graft and ££ in the long
run
craigd
Post Thu Aug 30, 2012 7:01 pm
I like the idea of spending the time building my car knowing exactly what problems came up during the build, and being able to say yes I built a car, not just brought one that someone already built. I have seen a few go fairly cheap, but again it's knowing what parts have been used, how well the works been done and if anything does ever break, which car the uprated parts came off.
e30den
Post Thu Aug 30, 2012 7:33 pm
Yeah know what you mean, recently finished building a hybrid lump for a golf gti.
and my e30 is finally back on the road this weekend after 3 years of hibernation
and a major overhaul.
if i was in your shoes i would go m50 all day long.
HairyScreech
Post Thu Aug 30, 2012 9:14 pm
If it is already an m20 then 300whp can be done on a b25 as has been seem quite a few times on various forums.
Would be a lot quicker and simpler to turbo an engine that is already in the car than fitting a different one and then turboing it.
400 crank hp is about 1.3 bar and can be done on stock internals.
A built m20 will happily do more power than a street e30 can realistically cope with so max upper limits are irrelevant unless your building a drag car.
Give gunni a shout on here, he will run you through the ins and outs.
craigd
Post Fri Aug 31, 2012 7:08 am
The only thing that keeps playing on my mind is how much strain will be put on the m20 lump by asking it to run at roughly double the power that it was designed to put out.
The time taken isn't the issue as its already been sat off the road for nearly 2 years whilst I save the funds
