http://www.bmminiparts.com
Kedge
Am i being REALLY thick or are BMMiniParts no longer stocking E30 parts, can't see the E30 listed anymore!
Mattyc
They are there bud - put your chassis number in and the available parts come up.
Duke137
You are thick Dave regardless
click on parts search and then select the "mobile tradition" option, E30 bits are in there
Be on your guard for them passing used damaged parts off as new and then accusing you of lying when you contact them to resolve the issue !
Kedge
I hate change!
Fairpoint, but then feck knows what that makes you! Got any nice M20B20 rods available?Duke137 wrote:You are thick Dave regardless
Duke137
I did have, but not any more lolKedge wrote:I hate change!
M20 rods in stock here !
its in mobile tradition
Mitchen
Went on here to order for the first time.. found some eccentric trailing arm bushes £33 for both sides.. Bargain I thought seeing as even Cotswolds wanted £50.85.
That was until I got to the checkout.. VAT added.. Shipping then added.. Suddenly my grand total is £49.68!
Not such a bargain after all!
Mitchen wrote:Went on here to order for the first time.. found some eccentric trailing arm bushes £33 for both sides.. Bargain I thought seeing as even Cotswolds wanted £50.85.
These can be bought from C3 (IIRC) for Ca £20 ! Febi brand which is OE.
Mitchen
Pete I know you're on the ball with the latest acronyms and slang.. but for the philistines on the forum, what's C3, and Ca?pacerpete wrote:Mitchen wrote:Went on here to order for the first time.. found some eccentric trailing arm bushes £33 for both sides.. Bargain I thought seeing as even Cotswolds wanted £50.85.
darkchild
