Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Post
Thu Aug 23, 2012 2:06 pm
Any one of you good people out there able to let me have two Hex nuts for the cam cover. I noticed two are missing.
There is no oil leak, so it's done pretty well..
I'll cover the P&P.
Thanks.
Ps. Or should I buy a complete set from the dealers? It's a 325.
verde
Post
Thu Aug 23, 2012 2:22 pm
Il sort you out babes. PM me your details
Raise hell praise Dale.
Gert_8
Post
Thu Aug 23, 2012 2:25 pm
Ah, cheers Verd, you're a good 'un
verde
Post
Thu Aug 23, 2012 2:41 pm
Check your inbox. I sent you a picture just to make sure thats what you need
Gert_8
Post
Thu Aug 23, 2012 2:47 pm
Hi, I just have and cannot open the link to photobucket - says page isn't there.
Gert_8
Post
Thu Aug 23, 2012 2:57 pm
Thanks Verde!
reggid
Post
Fri Aug 24, 2012 12:47 pm
just use a random nut M6 with washer there is nothing special about them
E30 325is with M20B31
Gert_8
Post
Fri Aug 24, 2012 12:50 pm
M6? Cool thanks for the info. Do you know the nut size for the headlamp washers. It's the one that fits at the end of the arm.
reggid
Post
Fri Aug 24, 2012 11:33 pm
Gert_8 wrote:M6? Cool thanks for the info. Do you know the nut size for the headlamp washers. It's the one that fits at the end of the arm.
metric 6mm = M6
most nuts/bolts/studs are M6, M8, M10 or M12........
look for it here
http://www.realoem.com/bmw/select.do?kind=P&arch=1
