DIY illuminated Gear Knob
Emm3
Hello all, I was going to buy an illuminated gear knob but at like £80 I think they are overpriced for what it is so I made my own it actually glows quite well at night, what you think
navi
unless you go dogging at night time,whats the point of a knob that lights up? proberly find your knob will light up a few days after going dogging.
bilal-ali
Looks Very good mate.
Any info on what you did?
rich318i
there napper leather and feel nice and are the some light as the clocks mine cost 70 over 4 yrs ago so id buy them now if you can
fearlessphil
X 2bilal-ali wrote:Looks Very good mate.
is your car a white 318is ?Emm3 wrote:Hello all, I was going to buy an illuminated gear knob but at like £80 I think they are overpriced for what it is so I made my own it actually glows quite well at night, what you think
+ a yard full of scrap turds
Emm3
Fairly simple, i got one 12v 3mm wide angle led, removed the shift emblem on the gearknob and drilled a hole in the centre of the gear knob so that the led can fit it. The wires for the led go through the gearknob and are fed through the leather gaiter to be wired to something like the illumination from the cig lighter.fearlessphil wrote:X 2bilal-ali wrote:Looks Very good mate.
Next i got some thin clear poly carb plastic cut into a circle the same size as the shift emblem and sanded it down so instead of it being clear it was a misty white.
With the led fitted into the centre of the gearknob the plastic piece is placed on top and then the shift emblem is refitted.
Note the wide angle led is flat at the top and and shines the light in a wider angle then a normal led. The plastic disc which i made was to diffuse the light into a glow as you tend to get spotting with just the led on its own.
Emm3
Mines a black onemagpie wrote:is your car a white 318is ?Emm3 wrote:Hello all, I was going to buy an illuminated gear knob but at like £80 I think they are overpriced for what it is so I made my own it actually glows quite well at night, what you think
polsta
good work, but could you modify it to amber ? either an amber led (with one of those sleeves on it) or an amber disc ?
- E30 Zone Meets/Events Team
I do the same Emm3 on my All in one Alcantara ones, but I take the wires down the outside of the gearknob.
Emm3
Mine might not appear in the pic but it lights up exact colour as the dash, I bought amber wide angle leds
Emm3
I got a bit carried away with the spare Leds I had and fitted one in each foot well for some footwell lighting a˜Š although you can see the Leds in the pics you can't see them at normal level and it leaves a dim amber glow on the footwell
polsta
ah ok cool, you can see it better in your pic of the foot well led there, looks well good, when its dark does it give a nice 100% even light up of the emblem ? , and is it wired so that it is on all the time day and night, or just when the lights are on ?Emm3 wrote:Mine might not appear in the pic but it lights up exact colour as the dash, I bought amber wide angle leds
Emm3
If you look really carefully you can see the light is stronger in the centre but the shift pattern and the numbers are are lit, on a night unless you examined it in detail it doesn't make much difference I wired the footwell lights and the gear knob to the cig lighter illumination don't see the point of a the gear knob being lit during day but suppose that's just choice. For the sake of less then a fiver you can't complainpolsta wrote:ah ok cool, you can see it better in your pic of the foot well led there, looks well good, when its dark does it give a nice 100% even light up of the emblem ? , and is it wired so that it is on all the time day and night, or just when the lights are on ?Emm3 wrote:Mine might not appear in the pic but it lights up exact colour as the dash, I bought amber wide angle leds
George
Looks good mate. Top modding
Sold: 1986 E30 325i Cabriolet, Alpine White
suchy
- True Zone Relic
Nice diy mod
verde
Make me one? Ha. Looks amasing. When I saw DIY I expected a home made dildo drift gear knob made out pvc pipe and stick on led strip. This is mint
Raise hell praise Dale.
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Excellent. makes me wish mine was a manual!
verde
Yours is an auto? I knew there was something off about youGert_8 wrote:Excellent. makes me wish mine was a manual!
