Bulkhead question + steering rack...
beautymeanswheels
Post Wed Aug 15, 2012 4:49 am
Silly question to the experts maybe... How do I go about examining the bulkhead on my e30 325i sport?
Thinking of changing the steering rack to improve steering. Seems as though the 20/30year old system is just that and will feel average at best after driving much newer cars. Whats my best option.. e36 m3/e46 325i? Other alternatives?
Also noticed something after buying the car, stupidly didn't open the petrol filler door. Stopped at the petrol station to put in petrol into the car on my way home. Flicked the little door open and was surprised to see that all that was present was filler cap and I could see the pipework going down to the tank. Could see the rear wheel?! :eek: :eek: :eek:
The prev owner has given the car a bit of a restore and there isn't any rust in that area. Just doesn't have the panel which fits around the filler cap. What can I do about it?
Prompt replies would be massively appreciated :D :D :D
Have some free tiem to address these things..
THANKS ALOT!
Post Wed Aug 15, 2012 6:29 am
There is a rubber cover which fits around the filler neck hole so you can't see the pipework
Naturally these are dealer only to buy new and expensive for what they are, and good secondhand ones the youngest being 20+ Years old are hard to come by :mad:
Put an ad in the wanted section - you might strike lucky :D
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Aug 15, 2012 7:58 am
To examine the bulkhead you need everything OFF the bulkhead in the engine bay. That means the heater blower access panel coming off as a bare minimum, as well as all the rubber sound-proofing and heat shielding (it's in three pieces).
Naturally, that means battery out, loom loosened, fuse box up, and brake master and servo off just for starters.
Post Wed Aug 15, 2012 10:25 am
steering rack upgrades [cheaply]
1. e36 3.2 lock-lock about £20 from scrapyard then you need custom parts from DanThe on here to make it fit.
p/s pipes £125 inc spacers for the rack to fit in the e30 x-member ,
you will need x2 e34 steering uj's about £20 each and a custom splined bar to fit them on about £65 again from DanThe.
the next upgrade is an e46 club rack 3.0 turns lock-lock about £50-£100 + all the other parts above.
i have an e36 rack fitted 8)
beautymeanswheels
Post Wed Aug 15, 2012 12:50 pm
Cheers guys...
Is there a step by step guide which shows how to examine bulk head with pics as guidance?
harry_p
Post Wed Aug 15, 2012 12:53 pm
one of the most usual places for the bulkhead to start rusting is where the main electrical look goes through.
remove the glovebox (assuming a rhd car) and have a poke about. if there are signs of rot, then it'll be worth digging further.
cheers,
harry
