GPS v SPEEDO
thecode
Post Thu Aug 09, 2012 11:35 am
Just wondering which is more accurate as the MPH on the sat nav is always 3-4 MPH less than the speedo on my Sport. :?
staley_turbo
Post Thu Aug 09, 2012 11:37 am
A 20 year old car or a gps sat nav? :mad:
ross_jsy
Post Thu Aug 09, 2012 11:44 am
By law your speedo has to over read. This is to account for things like tire pressure, wear etc etc
thecode
Post Thu Aug 09, 2012 2:29 pm
staley_turbo wrote:A 20 year old car or a gps sat nav? :mad:
It's the same situation on a e39, e46, e60
ross_jsy
Post Thu Aug 09, 2012 2:45 pm
ross_jsy wrote:By law your speedo has to over read. This is to account for things like tire pressure, wear etc etc
pud1
Post Thu Aug 09, 2012 2:51 pm
Trust your speedo and not the gps. Gps works on doppler effect and is an RF signal and just like any other RF signal is open to interference from whichever medium it passes thru. In the 20,000 km it travels to get to your receiver it goes thru many layers of space that have an attenuating effect on it. Its just like your tv signal passing thru low clouds, fog, and organic things like trees etc. They distort it. The Pentagon also has a nasty habit of turning on and off "selective acquisition" during times of conflict or terrorist activity. This makes the difference in accuracy of a few metres go up to 10, s if not 100,s of metres and hence any real-time position/speed calculation accuracy very unreliable.
Wiredjunkie
Post Thu Aug 09, 2012 2:52 pm
GPS nevers lies :screwy:
macas
Post Thu Aug 09, 2012 6:19 pm
You go through a 30 mph speed camera at 35 on you car speedo and the camera wont flash,you go through the same camera doin 35 on the satnav and it will flash you...
So the gps Is very accurate.
andyp
True Old Skooler
Post Thu Aug 09, 2012 11:24 pm
you cant get more accurate than a GPS
rich318i
Post Thu Aug 09, 2012 11:31 pm
its a 10% give 77mph on the clock is 70mph. but thats depends what inch rims your running
Barx325i
Post Thu Aug 09, 2012 11:36 pm
you can't get better than a kwik fit....GPS
b12rlw
Post Thu Aug 09, 2012 11:45 pm
My Impreza WR1 would read off the clock (160mph) +500rpm and would register 163 on the sat nav. Reckon with the accuracy of speedo's that'd be about right.
harry_p
Post Fri Aug 10, 2012 12:10 am
E30 speedos are actually pretty good for old cars, pretty much identical diff based speed sensor setup was certainly carried onto the e36, and wouldn't surprise me if current bmws were similar.
Far better than most cable setups anyway. As a teenager my mate had several minis, they all seemed to have a speedo needle that had a constant 10mph wobble so the speedo was only ever a rough indication!
Standard speedos do have to be optimistic so that they never under read, even with brand new tyres to a higher tolerance and at high pressure. A gps speedo never knows what it's attached to so will always display the actual speed to the best of its ability. Not ideal as there will always be some lag.
If your speedo is a long way out I'd look at the tyres, are they the right size? How much tread is left? Even then, tyre sizes aren't exact, different brands of 205 width tyres could be anywhere from 195 to 215mm wide, which also has an effect on the sidewall height which is a percentage of the width.
cheers,
harry
petchy
Post Fri Aug 10, 2012 3:47 am
andyp wrote:you cant get more accurate than a GPS
Except for DGPS. We use it on at sea for our dynamic positioning system. 10cm accuracy some people quote.
Morat
Post Fri Aug 10, 2012 9:04 am
DGPS isn't necessary when selective acquisition is turned off, but it is a good system.
GPS is more accurate than the speedo, but suffers a bit from Hysteresis (My word for the day) or lag. If you're accelerating or braking the GPS tends to tell you what speed you were doing 10-20 seconds ago.
