Is it illegal to clock a car if?
fearlessphil
i was wandering, i am about to change every bush ont the car, some because they need changing and some will need changing soon so theyre getting done aswell. while the diff is off getting its bush done im gunna have it referbed for peice of mind.
I am also wanting to turbo my m30 lump when i do it i want it doing right so the motor will have a full zero mile rebuild once that is done all that is left is wheel bearings and stearing rack so if ive come that far i may aswell replace , refurb them.
so after all that work the cars moving / wearable parts are all new so in my mind it makes sense to clock the odo to 0, would that be illegal? and what do you think it would do to the resale value?
Barx325i
It's only illegal if you try selling it with a false mileage, for instance, if your odo fails and you replace it's not breaking the law, but you are legaly obliged to record the mileage at the point it is replaced to offset that against the clock you're fitting
trying to sell a modded e30 with delivery mileage will look a bit suspicious more than affect the value in any great way
ross_jsy
I doubt it's legal, x works did it, but if a car was ever worthy that is one of them.
Also will wreck your resale. I wouldn't contemplate buying a car that has had this done.
So let me get this right? You want to renew a few bushes and whack a turbo on it and wind the clock back?
Whats your real name? Marty McFly?
Barx325i
But when that sucker reaches 88 miles per hour....B7 wrote:So let me get this right? You want to renew a few bushes and whack a turbo on it and wind the clock back?
Topblag
I think the key point is that the mileage is recorded against the car, not just the engine. A new engine on a 100k miles + car is not a new car.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Grrrmachine
- E30 Zone Wiki / Team Member
Remember that the chassis is an integral component of the car. Every sharp turn, every pothole, every bumpy road will flex the car, and metal doesn't remain elastic forever. The more you flex metal, the more brittle it gets over time, and while you can rebuild the engine you sure as hell aren't going to restitch every single welded seam on the shell (unlike what x-works did on his m3).
So while it's not illegal, it's certainly not justified.
fearlessphil
never thought about metal fatigue on the chassis very valid point!
I have no plans of selling the car its just for my own personal gain really (to lazy to bo a bit of maths!) I built a custom bike once that i clocked it was nice to glance down and know instantly where i was at (that was a proper custom re welded and heavily modded frame and brand new everything job so felt verry justified clocking it)
This x-works m3 sounds very interesting is there a web site or thread on it?
Barx325i
If you're not selling, and you have an agreed mileage policy and you stack it that can raise an issue if they notice your car has miraculously lost 120k, again at MOT stage it may also cause issues. Otherwise it's just a case of being able to give the correct mileage, regardless of the odo reading..
Grrrmachine
The x-works thread is a sticky at the top of this forum
HairyScreech
The only time it would be illegal is if you ever actually tried to pass the car off as having done less miles than it really has come insurance renewal/mot/resale time.
Other than that its not an issue.
HairyScreech
Nobby_N
Mileage is only a number! Nothing ilegal about it unless your selling it on and not telling the new owner its had its mileage corrected! I think unless you change every nut bolt engine part, gearbox, brakes, suspension, bushes etc you cant class it as new and 0 miles
e30mtech
hmmmmmmm i wonder................
if i put a bit gaffer tape over my missus' flangeeta would that make her a virgin again hmmmmmmmmm
cecotto479
- Caution Unreliable Seller
No you're not. There's no legal requirement to have a working odometer nor any record of mileage. If there is a record of mileage it can be illegal to falsely state or show that it is less than you know it is in truth if you're doing it to mislead someone into the belief that the car has done less than it has and therefore has an.increased value.Barx325i wrote:It's only illegal if you try selling it with a false mileage, for instance, if your odo fails and you replace it's not breaking the law, but you are legaly obliged to record the mileage at the point........
If you want to record the mileage of your rebuilt engine, there's nothing to.stop you zeroing the clock. Record the mileage before you set it go zero and keep the photos as part of your documented history. Eexpect some sceptical looks and questions come sale time though.
Good practice to record a speedo change in any event.
1981 E23 735i
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
e30mtech wrote:hmmmmmmm i wonder................
