E30 m3 Headlights question
E30_Maniac
Post Fri Jul 27, 2012 10:31 pm
Looking to replace my headlights on my e30 m3..
Does anyone know if all e30 headlights will fit my car or not?
Thanks..
harry_p
Post Fri Jul 27, 2012 10:43 pm
should do.
very early m3s might have had the pre-facelift sealed beam units (not sure ive seen one with them fitted though) which would need wiring modifications if you were to fit the later type.
cheers,
harry
Post Fri Jul 27, 2012 10:44 pm
Yes. As long as they are of similar age. Early M3s up till and including '87 model cars had the earlier non projector headlights with metal backings. The wiring on these is different to the projector equipped cars.
E30_Maniac
Post Fri Jul 27, 2012 10:46 pm
im looking to buy these..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... TQ:GB:1123
My m3 is 1988.. will they fit?
Thanks again
Post Fri Jul 27, 2012 10:52 pm
They should, IF your car is an '88 model as distinct from it being '88 registered. '88 cars should have NON smiley projector headlights. Any pics of the front of yours ?
The downside to fitting lights that are incorrect for your car, besides the fact that they are incorrect , is that many will assume your car has had a front ender :(
PS only septic turds had sealed beams.
E30_Maniac
Post Fri Jul 27, 2012 11:38 pm
I will try and get a picture of the front end of mine tomorrow and then maybe you guys can give me a better idea if they will definatly fit..
Thanks..
Post Fri Jul 27, 2012 11:57 pm
If you want some smoked ones i can supply those. :D
Post Sat Jul 28, 2012 12:00 am
harry_p
Post Sat Jul 28, 2012 12:07 am
Maybe he's not a chav :wink:
cheers,
harry
Barx325i
Post Sat Jul 28, 2012 12:08 am
easy harry, smoked headlights are mafia spec, don't diss :)
harry_p
Post Sat Jul 28, 2012 12:10 am
Smoked lights were awesome 6 years ago :D
cheers,
harry
Barx325i
Post Sat Jul 28, 2012 12:17 am
I am thinking about it. The build is gloss black and it may suit, or will I get slated? (for the headlights) :)
E30_Maniac
Post Sat Jul 28, 2012 1:43 am
No i deffo one standard ones.. trying to keep the m3 as original as poss..
Thanks for the offer tho.. 8)
Post Sat Jul 28, 2012 10:45 am
harry_p wrote:Maybe he's not a chav :wink:
careful you're showing your age. :wink:
Post Sat Jul 28, 2012 10:48 am
tellm
Post Sat Jul 28, 2012 12:41 pm
if your car is not uk spec and you buy uk spec lights i think the brackets end up in the wrong place thats what happened to me my beam was all over the place
harry_p
Post Sat Jul 28, 2012 3:08 pm
They shouldn't do, all front panels are the same, so assuming the car they came off was straight, and the car they're put on is straight, and they've not been fiddled with inbetween then they should bolt straight on and point roughly the right way.
The outer lights of all e30 projector type lights are adjustable for driving on either the left or the right.
cheers,
harry
E30_Maniac
Post Sat Jul 28, 2012 3:58 pm
Front end of my car..
I am looking to buy these lights.. Will they fit..
harry_p
Post Sat Jul 28, 2012 4:19 pm
Yes, they will be a straight swap, and definately better than the ones on there!
Keep an eye out for some 'bullseye' lights though if you want to keep the car totally original. They were only made for a very short time before they added the 'smile' under the central lens. Don't tend to be worth any more, despite their relative rarity.
cheers,
harry
Post Sat Jul 28, 2012 4:21 pm
E30_Maniac wrote:Front end of my car..
Your car has the early projector lights , so yes , the later 'smiley' type lights will fit and all the wiring is compatible.
Obviously they are incorrect for your car as is the red bumper tape :)
harry_p
Post Sat Jul 28, 2012 4:29 pm
Would a diamond Schwartz m3 have had plain bumpers, or would it have got black tape for a little bit of contrast?
cheers,
harry
E30_Maniac
Post Sat Jul 28, 2012 4:39 pm
Someones already messed around with the wiring before i got it so i dont think they will be as easy as a straight swap..
Thanks for your help! :)
harry_p
Post Sat Jul 28, 2012 4:47 pm
You should be able to swap the rear caps and bulbs over too. Leave them attached to what ever wiring is already there, just remove the light units, put te new ones in, clip te bulbs in twist the caps on.
Will also help if you can park in front of a wall or fence, mark the beam pattern with some chalk or masking tape, then you can check the alignment o the new ones when they're bolted in.
cheers,
harry
Post Sat Jul 28, 2012 4:53 pm
By the sound of your molested wiring, your car probably was fitted with the early non projector lights . Do as Harry says and you should be fine.
All M3s with the Exception of black Sport Evolutions left the factory with black bumper tape. It is available from your local dealer ready cut to fit fairly reasonably. Don't be tempted to use insulating tape, it looks crap.
E30_Maniac
Post Sat Jul 28, 2012 4:58 pm
Yes someone has molested the wiring as its unclear what should be what..
The car needs alot of attention so working on everything slowly..
Thanks for your advice guys..
Post Sat Jul 28, 2012 7:01 pm
I have some prefacelift lights that were correct for your car. :D
