Problem lifting horse shoe
E30123
Post Sun Jul 22, 2012 12:55 pm
I've got a manual cab, when I pop the lever open for the horse shoe, it unlocks fine, but when lifting it up, the metal frame is getting in the way on both sides, I have to fiddle about with it and need another person lifting it from the other side because of the frame! Surely the metal frame is not supposed to be that close??
mrLEE30
Post Sun Jul 22, 2012 7:18 pm
when you say it touches the frame i assume you mean the frame of the roof itself?? if so you have not folded it properly is the most likely answer, as the roof becomes older the straps that should tension it beceom loose and you need to fold it properly.
I have made a video that shows the opening and closing, pay attention to the fold i make at about 34 seconds where i fold the metal cross brace back, and then the fabric too. note my gas struts for the roof horseshoe are broken and thats why i hold it up or rest the roof on it.
hope this helps
bmwowner
Post Mon Jul 23, 2012 12:09 am
I sod about with my roof tucking the straps under the horse shoe for ages and did not know the roof should just drop in like that! Cheers for putting the video up mrLEE30. Nice one
mrLEE30
Post Mon Jul 23, 2012 2:14 pm
as will says you can change or re-tention the straps, or just live with it and fold it be hand....do you like my little foot shuffle between closing and opening!!! winkeye
Mo13
Post Mon Jul 23, 2012 4:09 pm
bmwowner wrote:I sod about with my roof tucking the straps under the horse shoe for ages and did not know the roof should just drop in like that! Cheers for putting the video up mrLEE30. Nice one
+1
Great stuff mrLEE30
torquey
Post Mon Jul 23, 2012 6:24 pm
diable wrote:How easy is it to re-tention the straps or to replace them?
Ditto
E30123
Post Mon Jul 23, 2012 8:03 pm
That's a very hopeful video mrLEE30, I too did not know about this middle bar.
My problem is slightly different though, I think Willnz is trying to explain the problem I have but not sure on how to fix this.
In the first pic, you will see what part is getting in the way.
The second pic is this bar near the back, I lift the rear part of the hood but this doesn't lift with it, I need to push this forward seperately and then the frame that is getting in the way has a little more clearance, I just nudge it forward and the horse shoe will go up/down. My concern is, I should need to budge the frame should I?
mrLEE30
Post Tue Jul 24, 2012 4:22 pm
watch my video again, pay attention to when i first close the roof at how at 10 seconds i use my elbow to fold the upper part of the window forward before i fold the lower part of the window fully, if you do not make this "elbow" fold the rear window will not fold fully forward causing the problem you show.
I make the same fold when i open the roof at about 20 seconds, you can see i make sure the window is not creased before i fold the window forward, while i check for creases i make the same "elbow" fold i mention above this allows the rear window to fold forward fully and then you have anough clearance to open the horseshoe, the part that i fold forward is the arm you circle in red.
does that make sense?
E30123
Post Tue Jul 24, 2012 9:34 pm
Ah yes you done it so smoothly, I never noticed the elbow move!
I get that now, but that corner part (first pic) stil gets in the way unless I nudge the frame forward. Ideally I would like it to clear without having to touch that frame
E30123
Post Tue Jul 24, 2012 9:39 pm
BTW, at 37 seconds, yuo move something back on the drivers side, I can't see what it is, it looks like just the cloth roof but there is a triangular kind of thing there
Cloggy Saint
Post Tue Jul 24, 2012 9:40 pm
mrLEE30 wrote:do you like my little foot shuffle between closing and opening!!! winkeye
I thought you were going to moonwalk to the other side of the car :)
mrLEE30
Post Fri Jul 27, 2012 3:39 pm
E30123 wrote:BTW, at 37 seconds, yuo move something back on the drivers side, I can't see what it is, it looks like just the cloth roof but there is a triangular kind of thing there
my passenger's side!
i fold the cross member back when i am on the side of the camera (my drivers side), thats what makes the loud CLACK noise, i then push the roof fabric the same way so it follows the corss member, i then (moon) walk to the other far side of the car and fold the other half of the fabric in the same manner, what you see at the very last second is the straps that WillNZ mentions earlier, i also fold that into the same way as the roof fabric, failing to do this step makes it very difficult to close the roof cover as the frame does not fold away properly.
with regards the windows i never wound them down if they were up, assuming your roof is correctly aligned and adjusted, same for the window adjustment you can see i have no problems.
E30123
Post Sat Jul 28, 2012 8:54 am
Cheers, I've managed to pretty much sort it now, this thread + the video has been a great help! :)
