I've been looking an injectortune's website and am thinking of having mine done. I was just wondering out of the people that have had theirs done, have you noticed a difference in power and mpg?
Having your injectors clean.
kitch
mcbonio
+1, would also like to know this.!
DHFiS
I had mine done. It didnt make a noticable change but I'm glad I had it done.
Cloggy Saint
Gavla
I changed mine for ones that had been done and I did notice an increase in mpg of about 10%
scott180gtb
I had mine done.
Smoothed out the idle.
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Captain_Birdseye
I asked my local bmw garage (Wellsway - Bath) and, even after they checked it on they're computer, they didn't know what to suggest. (Sorry lads!) In fact they did - told me to use some additives. So, good luck!
Barx325i
fancy some DIY?
this is a great video.. I did something similar myself with an aerosol cleaner and a inkjet syringe.. the wd style tube fits in the output end, and the injector pushes into the syringe plunger end. Operate the injector with a push button a battery & some small crocodile clips.. Worked a treat as a hand held setup, however one giant bang an awol injector and a face full of cleaner I decided to make a jig
Nothing this elaborate though..
Ajsingh
Had mine done on the 325i and it runs perfect when cold, no juddering or anything. Where as the 2.7 hasn't had the injectors cleaned and it jerks slightly when cold
E30 Crazy!
To state the obvious, how big an improvement you get depends entirely on how bad they are in the first place, but there is bound to be some deterioration after many 10s of 1000s of miles.
It's not just a case of cleaning them, but ensuring they're balanced as well.
Barx325i
more golden advice & this is the benefit of having them professionally cleaned.. throughput can be checked at home, but in videos I've seen, show injectors being held open for a determined length of time to check flow.. At home unless you alter the current to hold the injector open for a period, it can damage the coils. I'm not convinced holding them open is a good idea anyway, I was thinking of a digital controller to pulse them 100 (or more) times & measure the fluid they pass at a controlled PSI.Brianmoooore wrote:To state the obvious, how big an improvement you get depends entirely on how bad they are in the first place, but there is bound to be some deterioration after many 10s of 1000s of miles.
In practice, it's best sending them a few sets so they can pick out the ones whose peak flow match one another..
- **BANNED**
I have had the injectors cleaned by Injectortune on both cars.
Not a lot of difference on the M20 2.7,it ran better and gained 1.5mpg.
Huge difference on the M50,gained 3mpg and a lot more grunt.
Youth is wasted on the young.
