M42 breather system and alloy engine arm
Emm3
Post Sat Jul 14, 2012 3:24 pm
I'm changing one of the alloy engine arms on the i.s as for some reason it's got a big hole in it. Anyway how tight are the arms supposed to be on the engine I'd say the amount of force I used to undo the 4 bolts was probably the same as undoing a battery terminal?? Didnt seem right to me.
Also although the car seems to idle fine but I had a look at the breather system pipes as I know these engines rely on the breather system quite a bit.
Icv, one pipe goes into the rocker and the other goes under the manifold it's split icv side and also split where it joins the junction of pipes under the manifold
Then under the intake boot there is a single pipe that goes into junction of pipes under the manifold I think this just allows crankcase has to re enter the system it's also split engine side
Then you've got another breather pipe that goes from the cam cover (near oil cap) that also goes into this junction of pipes also split that side too.
I know I can just replace all the obvious pipes but I'm having ideas about simplifying the system and particularly removing the system where the crankcase gas re enters the system. I've seen it done on many na engines so guys have you any ideas??
DHFiS
Post Sat Jul 14, 2012 5:29 pm
Emm3
Post Sat Jul 28, 2012 4:20 pm
Guys im removing all that intake heating system on my car and I have taken the upper manifold off and the throttle body there's a heater plate between the throttle body and the manifold which I know will need to be refitted but just not plumbed, but there is another heater plate under the throttle body which slides in and is retained by a horse shoe shaped bracket I think I should be able to junk this, am I right?
Barx325i
Post Sat Jul 28, 2012 4:37 pm
yep you can junk that bit also..
