Rear passenger side wet carpet
jimbob29
Just noticed that rear passenger side carpet is soaking wet just that side tho no were else?the car is a saloon and I clean it out every week and has never been wet?the window was completely shut but there's always that little extra half a cm or so if you get what I mean!could that be enough to get the carpet wet?the arches and sills are in good condition.
Mo13
From a previous thread.....
Brianmoooore wrote:There is a large rubber grommet behind/underneath the glove box, with wiring looms passing through it into the engine compartment. Check that this is in place properly, the condition of the metal surrounding it, and the condition of the two 6mm studs on the bulkhead that the glovebox hinge bolts to.
If everything here is OK, pull back the carpet, and prod at anything that looks remotely orange with a pointed object.
e30den wrote:It is either rain water or a leak from the heater matrix [ check header tank ]
- **BANNED**
Just the rear p/s would lead me to suspect the floor bung in that area,or possibly the rear n/s sunroof drain.
However,if the entire p/s carpet area is wet,Mo13 is looking in the right places!
Youth is wasted on the young.
This is for the front. If it's only the rear that's wet, then the large twist in metal bung in the floor pan, below the back edge of the front seats, is the prime suspect.Mo13 wrote:From a previous thread.....
If everything here is OK, pull back the carpet, and prod at anything that looks remotely orange with a pointed object.e30den wrote:It is either rain water or a leak from the heater matrix [ check header tank ]
