old e28 525 engine
skooshy
Thu Jul 12, 2012 9:45 pm
is it the same as my face lift 325 ive herd sumthing about compression being different???
is that all (i no the loom and crank and stuff are different )
but bare engines side by side could they be swaped...
cecotto479
Caution Unreliable Seller
Thu Jul 12, 2012 9:48 pm
E28 525i is M30. Different engine altogether.
525e is M20. 2.7 eta version. That block attached to a better head etc. Is worthwhile. See the 2.7 section in the engine swaps bit.
1981 E23 735i
P10mike
Fri Jul 13, 2012 6:09 pm
Theres a 525e in u-pull-it winkeye
ikram
Wed Aug 01, 2012 8:32 pm
So, to convert a2.5 into a 2.7 you will need a e28 525e not 525i but e, what transmission is required auto? Or dose it matter
cecotto479
Wed Aug 01, 2012 9:49 pm
All 525e were auto IIRC. You'll need flywheel clutch, and spigot bush from an M20 to convert to manual.
1981 E23 735i
ikram
Thu Aug 02, 2012 2:17 am
Do I don't change pistons?
cecotto479
Thu Aug 02, 2012 7:38 am
1981 E23 735i
