m20 facelift and prefacelift, do mechanical parts fit both?
matt86
Post Thu Jul 12, 2012 3:28 pm
will a m20 prefacelift engine,box, wiring loom, exhaust system, prop, diff fit a facelift car.
Which parts out of the above will fit both.
I've been told for starter that the prefacelift and facelift engine wiring looms are different.
cheers
Prey
Post Thu Jul 12, 2012 3:37 pm
yes the looms are different - the management is a newer system on facelift. not sure how
many of the ancillaries would swap over though sorry.
i *think* the box, prop, diff etc will be the same though.
bmw9818
Post Thu Jul 12, 2012 6:10 pm
Doing a swap at the moment, the loom is defo different, think there are some differences to the vacuum to the brake servo on the inlet? :squint:
The heads are different as are compression ratios, don't know which ones better, think the older one is preferred,
Pre flift got two sensors in the gearbox, facelift got a toothed crank, CID lead and that,
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Jul 12, 2012 6:14 pm
You could physically unbolt the engine and loom and swap them over as a piece, with the only change needed at the C101 plug. Or you could remove the facelift, strip the management gear and fit it to the pre-facelift with no issues. The gearboxes differ only in the gearbox sensors as was mentioned, but a facelift gearbox bolts to the prefacelift engine with no problems, and the prop and diff will be identical.
But how "pre" are we talking about? Jetronic from 1983, or Motronic from 1987?
Post Thu Jul 12, 2012 6:17 pm
Jetronic was mainly 323i B23.. motronic was introduced along with the B25 donk IIRC,
I would use the lot, pre-facelift engine/box/prop with the facelift loom a great/easy swap if your facelift car is a 320i :D
Post Thu Jul 12, 2012 6:29 pm
If you're lucky enough to have found a good pre facelift 325 engine, it would be a missed opportunity to fit it into a facelift car without fitting the far more advanced facelift ECU complete with loom, onto it.
Basically, sit the old and new engines side by side, and swap over anything that is different.
Grrrmachine wrote:and the prop and diff will be identical.
Prop is identical, but the centre bearing housing is different. The mounting holes are further apart on the older version
