fuel pump relay
pjaystar
Post Sat Jul 07, 2012 6:01 pm
hello
went to move my car today and it would not start i could not hear the fuel pump removed the cover under the bonnet and only two relays no fuel pump relay.. i checked the fuse it was OK but had no power on it the car has been sitting for a while now.. is the fuel pump relay behind the glove box? and where is the dme relay
many thanks
Billwill
Post Sat Jul 07, 2012 6:25 pm
What model and year is your E30?
Most E30s the fuel pump only runs once the engine starts turning over and supplies crank pulses to the ECU. :?
pjaystar
Post Sat Jul 07, 2012 6:40 pm
325 tec 1 mate
pjaystar
Post Sat Jul 07, 2012 6:41 pm
1987
**BANNED**
Post Sat Jul 07, 2012 9:56 pm
willnz wrote:
bridge pins 30-87 and the pump should run.
That's the green/violet and red/white...if that makes it easier to locate!
pjaystar
Post Sun Jul 08, 2012 4:12 pm
Thanks i have the wireing diagram now but the relay is not under the black cover
Post Sun Jul 08, 2012 4:16 pm
You say you have two relays (plus an empty socket?). Why are you so sure that one of them isn't the pump relay?
