Newbie with a 318is, question regarding engine *FIXED*
lhd220turbo
Post Sat Jul 07, 2012 12:46 pm
Hi guys;
I've had lots of BMW's over the years, my current squeeze is a e46 323i daily and i've just picked up a e30 318is.
its a 1990 (h plate) 318is, 83k on the clock, the best bit is the shell is solid which i know is quite rare nowadays!
i bought it very cheap as sadly the previous owner has had a cracked head diagnosed. i'm in 2 minds wether to just replace like for like or go for a 328 conversion.
I'm pretty sure this engine will fit, can someone confirm? http://www.ebay.co.uk/itm/320925938892? ... 1423.l2649
sadly i dont know anyone with an ally welder as i suspect the head will be scrap if its cracked? or have they been repaired ok before
thanks
Matt
polsta
Post Sat Jul 07, 2012 12:51 pm
theres information regarding conversions on the zone wiki
theres an is engine for sale here..
http://www.e30zone.net/modules.php?name ... c&t=223229
lhd220turbo
Post Sat Jul 07, 2012 1:19 pm
polsta wrote:theres information regarding conversions on the zone wiki
Thanks, appreciated
Post Sat Jul 07, 2012 2:57 pm
you have a pm re m42 c/head
Captain_Birdseye
Post Sat Jul 07, 2012 5:08 pm
Good looking car.
DHFiS
Post Sat Jul 07, 2012 5:33 pm
The engine on Ebay will fit but if its out of an E36 you will need to swap the sump for an E30 one. If the pipe on the side of the head that is damaged is the one that feeds the throttle heater then you can blank it off.
Andyboy
Alpina Colada
Post Sat Jul 07, 2012 5:39 pm
You will need to swap the sump and both manifolds when fitting an E36 engine. Welding a cracked M42 head is risky because the cracks run very deep - I regard cracked heads as scrap. They crack on cylinders 2 and 3 from the exhaust valves to the waterways and the symptoms are the car starting on 2 or 3 cylinders, pressurising the cooling system and white steam from the exhaust.
I would fit another head rather than fit an untested 19 year old engine. The E36 head is the same but has thinner valve stems and single springs, neither of which make any difference to the way it goes. With the head off, it would also be prudent to remove the front timing cover to replace the chain and any other bits such as the jockey wheel and tensioner blade.
I've done a few M42's over the years - not a bad engine to work on.
I have a number of perfect cylinder heads although I can guarantee the £150 I ask (and get) will be undercut by many here! I have a pair of perfect engines as well.
lhd220turbo
Post Sat Jul 07, 2012 5:48 pm
thanks for the response, there's a guy selling a complete running engine on here which i might go for
or a trader has offered me a tested head
undecided what to do now, might be easier just to do a complete change.......famous last words
DHFiS
Post Sat Jul 07, 2012 6:03 pm
If your engine is has a good bottom end, doesnt burn oil or have a cam chain rattle then my advice is to fit a new head. 83k is a low mileage engine.
lhd220turbo
Post Sat Jul 07, 2012 7:55 pm
no chain rattle at all.
After having a little look tonight, i put a block tester on it and there is def an issue but i'm not convinced the issue is a cracked head, i guess it depends on where and how bad the crack is tho. The block tester showed up clear :-/
there is no misfire at all which i would expect, i'm hoping maybe its just a H/G, although there is a bill in the service history of a head gasket change in 2010....maybe it wasnt done very well
ive got tues & wed off work so i'll have a proper look at it, maybe whip the head off and get it pressure tested
Driftben
Post Sat Jul 07, 2012 8:21 pm
get the little M42 out of there and pop a M62 in there winkeye
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
lhd220turbo
Post Sat Jul 07, 2012 8:26 pm
Driftben wrote:get the little M42 out of there and pop a M62 in there winkeye
if i were 21 again, with no Mrs, no responsibilities & plenty of disposable income then i would!! :D
Driftben
Post Sat Jul 07, 2012 8:29 pm
Age and having a mrs has no play there matey, make a hobby out of it :wink:
6pot wilwoods front
4pot Porsche rear
Driftben
Post Sat Jul 07, 2012 8:57 pm
Hahaha exactly what I was thinking will
6pot wilwoods front
4pot Porsche rear
Andeep
Post Sat Jul 07, 2012 10:07 pm
You would need a new head gasket etc. and then there's the cost of having the head and block re-surfaced/skimmed. This all costs a fair bit (having seen a few engines being rebuilt) as well as taking quite a lot time. Then there is the chance of finding something that needs changing (profile gasket for example), so you will probably end up spending a bit more buying extra bits that don't seem perfect as well when rebuilding.
For a similar cost to changing the head, it would be worthwhile changing the engine for a low mileage, known working one. Far less work and probably quicker (don’t have to wait on machining work). Plus, you have a spare parts engine if anything were to break in the future.
lhd220turbo
Post Sat Jul 07, 2012 10:20 pm
decisions deisions!
Kedge
Post Sat Jul 07, 2012 10:36 pm
Andyboy wrote:You will need to swap the sump and both manifolds when fitting an E36 engine. Welding a cracked M42 head is risky because the cracks run very deep - I regard cracked heads as scrap. They crack on cylinders 2 and 3 from the exhaust valves to the waterways and the symptoms are the car starting on 2 or 3 cylinders, pressurising the cooling system and white steam from the exhaust.
^^^THIS^^^
Listen to the man that knows!!
Instagram - Kedge85
lhd220turbo
Post Sat Jul 07, 2012 11:00 pm
so what's a head gasket going to cost from the main stealers? can i re-use head bolts, if not what do they add to the cost?
Andyboy
Alpina Colada
Post Sun Jul 08, 2012 10:47 am
A genuine gasket is around £80 or failing that a Reinz gasket - accept no substitute. Cheap gaskets fail after a year. Bolts must be renewed, but they're @ £15 from a factors. Profile gasket is a few quid from BMW. The steel manifold gaskets can go again. With the head off, the cracks are easy to spot. Measure the head with a steel rule for 'bend' and skim it by the bare minimum. You need the extra thickness BMW gasket.
lhd220turbo
Post Sun Jul 08, 2012 11:15 am
Andyboy wrote:A genuine gasket is around £80 or failing that a Reinz gasket - accept no substitute. Cheap gaskets fail after a year. Bolts must be renewed, but they're @ £15 from a factors. Profile gasket is a few quid from BMW. The steel manifold gaskets can go again. With the head off, the cracks are easy to spot. Measure the head with a steel rule for 'bend' and skim it by the bare minimum. You need the extra thickness BMW gasket.
thanks for the response, so the extra thick H/G gasket is the one to go for then, i dont suppose you or anyone know's the part number?
Andyboy
Alpina Colada
Post Sun Jul 08, 2012 12:11 pm
11121721550
Andeep
Post Sun Jul 08, 2012 1:40 pm
This looks like a nice tried and test engine to go for
lhd220turbo
Post Sun Jul 08, 2012 8:46 pm
Andyboy wrote:11121721550
thanks, thats very helpful
HairyScreech
Post Wed Jul 11, 2012 11:51 am
Interesting you should say that, the Americans slam the Victor reinz basket with a lot of failures reported. Suggestion is to go goetze or elring.
Perhaps that info is m20 specific though?
Andyboy
Alpina Colada
Post Wed Jul 11, 2012 1:36 pm
Goetze and Erling are also okay as are some Payen gaskets. I would still be using a BMW gasket though, job done. It's not worth pissing around to save 30 quid.
lhd220turbo
Post Thu Jul 12, 2012 7:12 pm
evening gents;
ive got a bit of an update but still have an issue, so i'm hoping someone can shed some light.
got the car back to a friends workshop, was going to run it up to temp and see what issues i have. now i bought this car with a suspected cracked head.
started the engine to find the radiator was leaking badly, so i've now put a new rad in it. Started engine and bled system and the engine is idling perfect, no white smoke, good heat through vents and temp gauge half way. took it for a run up the road, temp gauge did rise briefly but then settled to midway again...maybe slight air in system?
anyway, took it out again and it started to lose power quickly, so bad that as soon as i touched the throttle it would die. (still good temp wise etc), pulled over where it stalled, would not restart immediately so left it for a while.
10 mins later restarted but not idling correctly and would stall if i tried to open throttle, car smelt of fuel when it restarted.
got it towed back, and my initial thoughts were dodgy fuel pump or blocked exhaust? removed the fuel line in the bay to see and there wasnt much pressure while cranking?
my question is are these fuel pumps prone to packing up? if it is fuel pump i'm not sure why its fine while its cold but gives up after warming up?
kinda rulled out exhaust as there seems to be good flow and doesnt sound blocked.
any ideas guys, any common problems than can cause this type of issue?
Matt
Post Thu Jul 12, 2012 11:24 pm
check for fuel leak in the rubber pipes under the bonnet or the metal fuel rail small hoses.
when you turn the key to position 1 or 2 you will hear the pump prime ,if no pump you can get to it via an inspection hatch under the rear seat on the drivers side.i used to give mine a whack and it would come back to life until it died for good a few month later.
Andyboy
Alpina Colada
Post Fri Jul 13, 2012 10:05 am
If it stinks of fuel from the exhaust, it's flooding. I'd be looking at the coolant temperature sensor. It's buried under the inley manifold in the centre of the head in the most inconvenient place. However I'm not sure it's that. When these fail, the engine will not idle and will only operate at higher rpm to avoid stalling and severe bogging down.
It could also be a sticking air flow meter (does the flap move smoothly?) or about a hundred other things. Fuel pressure regulator, blocked fuel filter etc etc etc.
redcar
Post Fri Jul 13, 2012 10:14 am
As Andyboy said, try testing the blue coolant temp sensor. Test it at the loom ECU plug just to make sure the wiring to the plug isn't at fault.
Is the ICV, TPS and AFM all working and good? Test to wiring to these components as well. The wiring can disconnect from the actual plug.
Does your car have a lambda? IIRC theres a little connector under the wiring loom cover on the bulkhead that should be disconnected or connected dependant upon whether you have a lambda sensor.
What are the spark plugs like. Coil packs all good? Any air leaks?
Try do a compression test on it also.
lhd220turbo
Post Fri Jul 13, 2012 9:09 pm
thanks for the replies guys, few more ideas for me to check
funnily enough i had a rwd cosworth a few years back, that used to overfuel when i first got it and that was a blue temp sensor, would overfuel once warm as it thought the engine was cold.
anybody know what the fuel pressure should be on these?
lhd220turbo
Post Mon Jul 16, 2012 6:52 pm
well, that was a stroke of luck, the problem is now fixed - turned out to be a duff fuel filter. I was right with a fuel issue but i didnt expect it to be that simple!!! result
redcar
Post Mon Jul 16, 2012 6:56 pm
lhd220turbo wrote:well, that was a stroke of luck, the problem is now fixed - turned out to be a duff fuel filter. I was right with a fuel issue but i didnt expect it to be that simple!!! result
Haha awesome. Good job you didn't waste any money then!
Just hope that running lean hasn't caused any damage to the engine. :D
lhd220turbo
Post Mon Jul 16, 2012 7:06 pm
indeed - makes a change for an easy fix
